Offset Resistors?
Ok, this isn't a finished circuit but it's made some use of the bent and insulated wire ends. The tip is to pick up the wire and replace it on the board once you've tweaked it so that it snaps into the right place....
I'm ignoring the power rails as I don't have them on my board and I've tried to simulate LED with the limiting resistor soldered as a space saving trick. I think it looks ok but an offset might be useful (like the wires) to help reveal connections to the holes below.
These new bent and offset wire mean that we don't need anything other than straight ends on the switch. This in turn would give more flexibility on placement and wire connections to the board. I'd like to make another switch connection to I2, it's going to be odd but the straight termination on the switch could make this easier. (current wire offsets allow us to align with the switch terminations).
The more I use this the more I like it, I loved it before!
regards,
colin
Code for this circuit:-
regards,
colin
IC||766|270|1|L293D|U?|||L293D|IC||L293D_1
IC||524|270|1|PICAXE 18X|U?|||PICAXE18|IC||PICAXE18_1
Wire||856|240|11||11|#000000|1|11|||
Wire||856|377|11||11|#000000|1|11|||
Wire||883|399|11||11|#000000|4|12|||
Wire||883|212|11||11|#000000|4|14|||
Wire||979|212|22||22|#000000|7|33|||
Wire||748|377|11||11|#CC6633|2|11|||
Wire||748|240|11||11|#CC6633|2|11|||
Wire||721|368|12||11|#CC6633|8|11|||
Wire||721|243|13||11|#CC6633|8|11|||
Wire||640|212|11||11|#FF0000|5|11|||
Note||913|149|1||||||Motor 1||NOTEPAD_1
Note||764|149|2||||||Motor 1||NOTEPAD_2
Note||762|452|2||||||Motor 2||NOTEPAD_2
Note||915|451|1||||||Motor 2||NOTEPAD_1
Wire||775|408|13||12|#FF9900|8|12|||
Wire||964|240|11||12|#FF9900|1|14|||
Wire||989|240|21||23|#FF9900|6|33|||
LED|0|640|366|1|LED|LED?|1|||IC||led_11
Resistor|330|535|373|1|Resistor|R?||2||IC||
Wire||602|377|11||12|#000000|1|33|||
Wire||506|377|11||13|#000000|1|13|||
Wire||506|435|13||12|#000000|5|11|||
LED|0|667|394|1|LED|LED?|2|||IC||led_21
Resistor|330|535|401|1|Resistor|R?||2||IC||
Wire||506|405|11||11|#000000|1|13|||
Wire||602|405|11||12|#000000|2|33|||
Switch||388|595|1||SW?|1||1|Switch||switch_111
Wire||504|462|21||12|#3253FF|5|13|||
Wire||531|463|13||21|#00A060|3|41|||
Wire||531|469|21||32|#00A060|5|33|||
Resistor|47000|535|428|1|Resistor|R?||2||IC||
Wire||512|249|23||32|#00A060|7|44|||
Wire||522|243|13||11|#00A060|4|31|||
Wire||513|432|11||33|#00A060|1|33|||
BREADBOARDSTYLE=BB10
