PEBBLE V2.5 bug fix
@pilko and slurp,
Yes, I have found there is a bug. (thanks for that)
When you restart PEBBLE it has not loaded the BB images (part of the new feature) but when using the load/save function to bring an old circuit back in, it did not check and reload the required BB
ATTACHED IS THE V2.5 FIXED FILE
change the extension from .txt to .js and
copy it into your PEBBLE/javascript directory
@pilko/slurp, If you can confirm that this rectifies the bug as identified I will pass the correction on to all sites who may host
@pilko and slurp,
