@Mpep,
I think that you first muted RS485 - my research I find has a lot of enhanced devices on the market today with some mfrs coming in with failsafe, 256nodes at around entry level pricing whilst others offer the same technology as their enhanced products. I particularly like the LTC1487 from Linear Technology (low EMI version). In fact Rapid here in the UK have discontinued the 8DIP package and the 8SOIC package is available until stock runs out. Not having circuit board facilities it's a bit of a bummer, but will be buying in ten 8SOIC for mounting dead bug fashion, impressed by the spec at the price. I will also buy at a slightly lesser price a couple of SIpex SP485CN (bog standard spec). I have learned a lot since I last really looked at RS422 20+ years ago. Thank you.
My own application is smaller and not rigerous, to monitor a couple of beehives, but I just helped a friend put 114 hives into one apiary to overwinter - now that would be interesting (futile perhaps)!
Back to the subject:
Post #3
Temp Range
The temp range would be around
15 to 100 C
and yes I do want 1 temp sensor per bearing and 1 led indicator per bearing.
Post #64
What is hot?
there is disagreement on this too. appx 140 is getting hot and 170 is really hot. 200 is cooked. ill need to contact Cooper bearing and get a specific range.
I am assuming the latter figures are degrees Fahrenheit, based upon the post #3 estimate and the use of Fahrenheit by the crew. this was mentioned earlier as the vessel is US registered and has a US crew.
They are happy with that, it's the bearings that they don't want U/S
Big advantage to the DS18B20 is that it's directly supported by the Picaxe firmware. The LM95172 would present interface problems as it is unlikely to use the OneWire protocol used by readtemp. If it was effecively a drop in replacement at the right price It might be attractive.
I can find no regular local supplier here in the UK and the best price I seem to be able to come up with is around 27 USD.
http://www.findchips.com/avail/?part=LM95172&partner=DS4U&utm_source=DS4U&utm_medium=Link
Your go . . .
I remain to be convinced about the code to handle this device, suitable suppliers (anywhere) and a reasonable price.
Honest, I'm only an advocate and not the Devil . . .
Difficult to tell at times though!
