More information would certainly be helpful.Is it possible to use Picaxe
to work with PWM on the input from 800 pwm to 2000 PWM
Plan is to work with the signal come from RC reviver
I want to read 4 channelIts not at all clear to me, and I guess most of us, what you are trying to do.
Do you have a circuit diagram ?
How many RC channels are you reading, how many outputs do you want to control ?
All necessary information before readers start guessing or making assumptions.
the lower value on a input will be around 1100 PWM nad the higest around 1900 PWMAs srnet states, more clear description would be very helpful.
You know what you want to achieve - try to prevent assumptions/guesses and the solution can come much afster.
Working in the assumptions raised thus far,
If the pulse durations are between 800 us and 2000 us, then, using the PULSIN command and assuming a PICAXE clock frequency of 4 MHz then the min value returned is 80 and the max is 200. Subtract 80 and you have a value in the range 0 to 120.
Since you want 5 “bands”/stages then use the modulus function where
<returned value> // 24
will give a value of 0 to 4 with returned values of 0 to 119, but 5 if a 2000 us pulse is received. Alternatively divide by 25 ( // 25 )
the PPM signal is the 1 that use From transmitter to the receiverThe confusion seems to stem from the misused terminology.
RC command signals use PPM, Pulse Position Modulation, not PWM which is Pulse Width Modulation.
To read RC PPM you just need to decode the position of the pulse you are interested in relative to the longer start pulse in the frame. This article has an illustration: http://www.hobbytronics.co.uk/decode-rc-control-ppm
'Radio control 4 channel switch using PICAXE-18
'Kevin Goom 8 October 2005
'Use, abuse, modify distribute freely, but at your own risk.
'Any channel can operate in latched or unlatched operation.
'For latched operation tie legs 18,17,16,15 to +5V for channel A to D respectively.
'Outputs (legs 6,7) will then go high the first time the receiver pulse goes above the threshold, and low the next.
'Outputs (legs 8,9) will then go high the first time the receiver pulse goes below the threshold, and low the next.
'For unlatched operation,legs 6,7 are high when the receiver pulse goes above the threshold and vice-versa.
'For unlatched operation,legs 8,9 are high when the receiver pulse goes below the threshold and vice-versa.
'Change the values b11 as desired to change the switching points.
'PICAXE-18 connections are:
' Leg 1 (In2) Pulse input from radio receiver
' Leg 2 (Serial Out)
' Leg 3 (Serial in) Tie to Ground through 10K resistor
' Leg 4 (Reset) Tie to +5V through 4.7K resistor
' Leg 5 Ground
' Leg 6 (Out0) Channel A output
' Leg 7 (Out1) Channel B output
' Leg 8 (Out2) Channel C output
' Leg 9 (Out3) Channel D output
' Leg 10 (Out4) Not connected
' Leg 11 (Out5) Not connected
' Leg 12 (Out6) Not connected
' Leg 13 (Out7) Not connected
' Leg 14 +5V
' Leg 15 (In6) Channel D latching option (+5V=latching, ground=non-latching)
' Leg 16 (In7) Channel C latching option
' Leg 17 (In0) Channel B latching option
' Leg 18 (In1) Channel A latching option
symbol OutA=0 'Name channel A output pin (leg6)
symbol OutB=1 'Name channel B output pin (leg7)
symbol OutC=2 'Name channel C output pin (leg8)
symbol OutD=3 'Name channel D output pin (leg9)
symbol LatchedA=pin1 'Name channel A latch option pin (leg18)
symbol LatchedB=pin0 'Name channel B latch option pin (leg17)
symbol LatchedC=pin7 'Name channel C latch option pin (leg16)
symbol LatchedD=pin6 'Name channel D latch option pin (leg15)
symbol Pulse_Width=w6 'Name measured input pulse width
symbol Prev_Pulse_Width=b2 'Name previous measured input pulse width
symbol Pulse_In=2 'Name pulse input pin (leg1)
'Initialise
Restart:
pins=%00000000 'Set all outputs low initially and on loss of input
Start:
pulsin Pulse_In,1,Pulse_Width 'Measure and store input pulse
if Pulse_Width<50 or Pulse_Width>250 then Restart 'Go back if input pulse lost
b10= LatchedA
b11=180 'Set channel A threshold to 1.80 ms
b6=0 'Set to switch channel A (Out0)
b7=1 'Set to switch channel A (and B) to up mode
gosub Check 'Check for up-switching on channel A
b10= LatchedB
b11=160 'Set channel B threshold to 1.60 ms
b6=1 'Set to switch channel B (Out1)
gosub Check 'Check for down-switching on channel B
b10= LatchedC
b11=140 'Set channel C threshold to 1.40 ms
b6=2 'Set to switch channel C (Out7)
b7=0 'Set to switch channel C (and D) to down mode
gosub Check 'Check for down-switching on channel C
b10= LatchedD
b11=120 'Set channel D threshold to 1.20 ms
b6=3 'Set to switch channel B (Out1)
Prev_Pulse_Width=Pulse_Width 'Reset previous pulse width to current pulse width
goto Start 'Go back to measure input pulse again
Check:
if b10=1 then Latch 'Check whether channel is latched operation
'Unlatched operation
if Pulse_Width>b11 and b7=1 then Out_On 'Check whether pulse is longer than threshold, up mode
if Pulse_Width<b11 and b7=0 then Out_On 'Check whether pulse is longer than threshold, down mode
low b6 'Turn off output if pulse beyond threshold
Return 'Exit Check subroutine
Out_On:
high b6 'Turn on output if pulse beyond threshold
Latch: 'Latched Operation
if Prev_Pulse_Width<b11 and b7=1 then Thold 'Check whether previous pulse beyond threshold, up mode
if Prev_Pulse_Width>b11 and b7=0 then Thold 'Check whether previous pulse beyond threshold, down mode
Return 'Exit Check subroutine if previous pulse above threshold
Thold: 'Previous pulse below threshold
If Pulse_Width<b11 and b7=1 then Finish 'Check whether pulse is beyond threshold, up mode
If Pulse_Width>b11 and b7=0 then Finish 'Check whether pulse is beyond threshold, down mode
toggle b6 'Toggle output if pulse is beyond than threshold
Finish:
Good "pick-up" Jeremy.The confusion seems to stem from the misused terminology.
Reading the output from an RC receiver can be done very simply using the pulsin command. This will result in a value of about 100 to 200 representing the position of the transmitter stick for that channel. You will need to but the pulsing command in an infinite loop, and take whatever action you want base on the value read. You could get clever with some code at the start of the program in order to find the maximum, neutral and minimum pulse widths, or use some trial-and-error testing to find these values, and hence set thresholds for various actions. Below is some code that I wrote for a 4-channel RC switch which you may find useful as a basis for your own code.Code:'Radio control 4 channel switch using PICAXE-18 'Kevin Goom 8 October 2005 'Use, abuse, modify distribute freely, but at your own risk. 'Any channel can operate in latched or unlatched operation. 'For latched operation tie legs 18,17,16,15 to +5V for channel A to D respectively. 'Outputs (legs 6,7) will then go high the first time the receiver pulse goes above the threshold, and low the next. 'Outputs (legs 8,9) will then go high the first time the receiver pulse goes below the threshold, and low the next. 'For unlatched operation,legs 6,7 are high when the receiver pulse goes above the threshold and vice-versa. 'For unlatched operation,legs 8,9 are high when the receiver pulse goes below the threshold and vice-versa. 'Change the values b11 as desired to change the switching points. 'PICAXE-18 connections are: ' Leg 1 (In2) Pulse input from radio receiver ' Leg 2 (Serial Out) ' Leg 3 (Serial in) Tie to Ground through 10K resistor ' Leg 4 (Reset) Tie to +5V through 4.7K resistor ' Leg 5 Ground ' Leg 6 (Out0) Channel A output ' Leg 7 (Out1) Channel B output ' Leg 8 (Out2) Channel C output ' Leg 9 (Out3) Channel D output ' Leg 10 (Out4) Not connected ' Leg 11 (Out5) Not connected ' Leg 12 (Out6) Not connected ' Leg 13 (Out7) Not connected ' Leg 14 +5V ' Leg 15 (In6) Channel D latching option (+5V=latching, ground=non-latching) ' Leg 16 (In7) Channel C latching option ' Leg 17 (In0) Channel B latching option ' Leg 18 (In1) Channel A latching option symbol OutA=0 'Name channel A output pin (leg6) symbol OutB=1 'Name channel B output pin (leg7) symbol OutC=2 'Name channel C output pin (leg8) symbol OutD=3 'Name channel D output pin (leg9) symbol LatchedA=pin1 'Name channel A latch option pin (leg18) symbol LatchedB=pin0 'Name channel B latch option pin (leg17) symbol LatchedC=pin7 'Name channel C latch option pin (leg16) symbol LatchedD=pin6 'Name channel D latch option pin (leg15) symbol Pulse_Width=w6 'Name measured input pulse width symbol Prev_Pulse_Width=b2 'Name previous measured input pulse width symbol Pulse_In=2 'Name pulse input pin (leg1) 'Initialise Restart: pins=%00000000 'Set all outputs low initially and on loss of input Start: pulsin Pulse_In,1,Pulse_Width 'Measure and store input pulse if Pulse_Width<50 or Pulse_Width>250 then Restart 'Go back if input pulse lost b10= LatchedA b11=180 'Set channel A threshold to 1.80 ms b6=0 'Set to switch channel A (Out0) b7=1 'Set to switch channel A (and B) to up mode gosub Check 'Check for up-switching on channel A b10= LatchedB b11=160 'Set channel B threshold to 1.60 ms b6=1 'Set to switch channel B (Out1) gosub Check 'Check for down-switching on channel B b10= LatchedC b11=140 'Set channel C threshold to 1.40 ms b6=2 'Set to switch channel C (Out7) b7=0 'Set to switch channel C (and D) to down mode gosub Check 'Check for down-switching on channel C b10= LatchedD b11=120 'Set channel D threshold to 1.20 ms b6=3 'Set to switch channel B (Out1) gosub Check 'Check for down-switching on channel B Prev_Pulse_Width=Pulse_Width 'Reset previous pulse width to current pulse width goto Start 'Go back to measure input pulse again Check: if b10=1 then Latch 'Check whether channel is latched operation 'Unlatched operation if Pulse_Width>b11 and b7=1 then Out_On 'Check whether pulse is longer than threshold, up mode if Pulse_Width<b11 and b7=0 then Out_On 'Check whether pulse is longer than threshold, down mode low b6 'Turn off output if pulse beyond threshold Return 'Exit Check subroutine Out_On: high b6 'Turn on output if pulse beyond threshold Return 'Exit Check subroutine Latch: 'Latched Operation if Prev_Pulse_Width<b11 and b7=1 then Thold 'Check whether previous pulse beyond threshold, up mode if Prev_Pulse_Width>b11 and b7=0 then Thold 'Check whether previous pulse beyond threshold, down mode Return 'Exit Check subroutine if previous pulse above threshold Thold: 'Previous pulse below threshold If Pulse_Width<b11 and b7=1 then Finish 'Check whether pulse is beyond threshold, up mode If Pulse_Width>b11 and b7=0 then Finish 'Check whether pulse is beyond threshold, down mode toggle b6 'Toggle output if pulse is beyond than threshold Finish: Return
