That post was made in desparation.Perception is reality Boriz.
@GAP please give us a copy of your program, ensuring that we are fully aware of the chip that is the target. A photo of the chip layout of your circuit and maybe a circuit diagram would all help, maybe immensely.
Your ball!
;This program reads the adc input from C.4(left) or C.0 (right) to trigger flashing
;lights and to lower or raise a boom on a model train layout.
;The program will trigger on whichever adc input changes from high to low first,
;when this happens it starts the flashing lights and lowers the boom.
;It then waits till the opposite adc input to the triggering input changes
;from high to low, signifying that the train has passed
;and then turns off the lights and raises the boom.
symbol left=b0
symbol right=b1
SYMBOL countr = b2
SYMBOL servopin = b.4
SYMBOL servopina = b.5
start:
Low B.1 ;Set B.1 as an output and low
Low B.2 ;Set B.2 as an output and low
b5 = 0 ;this is to keep track of the state of the lights
readadc c.4,left ;read adc into variable b0
readadc c.0,right ;read adc into variable b1
readadc c.4,left ;looks at both inputs
readadc c.0,right
if left>150 then ;if left is greater than 150 then flash lights and lower booms
GoSub ChangeLights
GOSub BoomDown
GoSub ChangeLights
readadc c.0,right
If b4 =5 Then
GoSub ChangeLights
b4 = 0
end if
inc b4
loop while right<150
readadc c.0,right
if b4 =5 Then
GoSub ChangeLights
b4 = 0
end if
inc b4
loop while right>150
end if
if right>150 then
readadc c.4,left
if b4 =5 Then
GoSub ChangeLights
b4 = 0
end if
inc b4
loop while left<150
readadc c.4,left
if b4 =5 Then
GoSub ChangeLights
b4 = 0
end if
inc b4
loop while left>150
GoSub ChangeLights
GoSub BoomUp
GoTo start
end if
GoTo Start
ChangeLights: ;this sets which light is on/off based on the value of the b5 variable
;and then XORs (flips it between 1 and 0) it so that next time the sub is called
;it switches them back.
if b5 = 0 then
low B.1
high B.2
pause 300
low B.2
High B.1
high B.1
low B.2
pause 300
high B.2
low B.1
b5 = b5 XOR 1
BoomUp:
servo B.4,150 ;set servos at 150
servo B.5,150
for countr = 140 to 225
servo B.4,countr
servo B.5,countr
servo B.5, countr
if b4=5 Then
GoSub ChangeLights
b4=0
end if
pause 1
next countr ;increment counter by one count
BoomDown:
servo b.4,225 ;set servos at 225
servo b.5,225
for countr = 225 to 140 step -1
servo b.4,countr
servo b.5,countr
servo B.5,countr
if b4=5 Then
GoSub ChangeLights
b4=0
end if
pause 1
next countr ;decrement by one count
#PICAXE 14M2
#Terminal 4800
SerTxd("Booted 14M2", CR, LF)
SerTxd("Left=", #left, ", Right=", #right, CR, LF)
Not looked at the detail, but b6=1000 will fail (well it won't fail, but it won't do what you expect)....the Bx variables can only hold values 0 to 255 inclusiveProbably is the simulator delay - to make it simpler to find the correct delay make a symbol delaylight = b6 then b6=1000 (say) and replace all the pause 300 statements with pause delaylight.
Then you only have to change 1 line to vary the flash delay
Welcome to the real world where 0's and 1's are not necesserily what you think they are.
Unless you've done something really silly, the PICAXEs are unlikely to be damaged. They're tough little beasties.
You don't describe your hardware at all. Do you have the download curcuit (10k + 22k resistors) permanently connected to your PICAXE?
Initially, leave your programming cable connected to your circuit while you debug your hardware and software.
Add the following directives near the top of the Symbols.
Add this command in the line before the Start: labelCode:#PICAXE 14M2 #Terminal 4800
Add the following command immediately after the ReadADC commands (you don't need to repeat the ReadADC commands like you have in the code you posted).Code:SerTxd("Booted 14M2", CR, LF)
Report back what gets reported to the terminal window and we'll see how else we can help.Code:SerTxd("Left=", #left, ", Right=", #right, CR, LF)
You do not need a variable at all. Define a constant with:Whoops should have said a w6 word variable now fixed.
@ West aust55 the other thread was me I walked away from this for a while but have come back to it.@GAP,
Suggest that you read up on the TOGGLE command.
Then one command can replace the need to store the current state of the LEDs, and separate groups of high and low commands to flash them.
Looks like another model railway boom gate lriject.
If you do a search of the PICAXE forum ther was another quite recent thread on the same topic.
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=13
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=13
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=11, Right=14
Left=11, Right=12
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=13
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=8
Left=11, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=13
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=9, Right=8
Left=13, Right=21
Left=17, Right=24
Left=20, Right=23
Left=17, Right=21
Left=16, Right=20
Left=16, Right=19
Left=15, Right=14
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=11
Left=10, Right=10
Left=9, Right=8
Left=13, Right=21
Left=17, Right=23
Left=17, Right=22
Left=16, Right=21
Left=16, Right=19
Left=15, Right=15
Left=12, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=11
Left=10, Right=10
Left=10, Right=9
Left=11, Right=14
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=12, Right=14
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
Left=10, Right=9
Left=11, Right=15
Left=11, Right=13
Left=11, Right=12
Left=10, Right=10
I am now totally confused because that readout was from the picaxe in my programming setup. ie nothing is commented just the 10K and the 22K programming resistors.This is where you'll have to help yourself. The PICAXE does not appear to be rebooting all the time, so that is a good sign.
The left input looks very stable but the right one is changing in a regular sawtooth fashion. Is that supposed to happen? Check that the right sensor is connected properly.
You now need to apply the left and right values to your code. What should it do and compare that to what actually happens. Add more "SerTxd" commands as I have suggested, to other parts of your code to see what happens.
This may be significant.There is no download circuit on the bread board, I have an 08M2 and a 14M2 download circuits on seperate small boards mounted on a piece of wood.
I download the program into the chip then remove the chip and put it in the holder on the breadboard to run the program.
tags around it to keep it compact.
Firstly, I didn't see your post #10 when I replied last. Sorry I missed it. It sort of explains why one of the ADC readings is cycling up and down: it's probably 50Hz mains radiation being picked up by the unterminated ADC input.
Not having a download circuit on your (not) working circuit makes it almost impossible to debug both code and hardware. I suggest you add a stereo socket with flying leads soldered to your project so that you can see debugging data. The 10K and the 22K programming resistors are required, of course, but they are required regardless: the PICAXE will not be stable without them.
Once you can log the output from the PICAXE when it is plugged into your project, post some of it so we can see what is happening. Actually, you should be able to see the ADC values in the log change as you illuminate/shade the LDRs. When posting long pieces or code or logs, wrapCode:tags around it to keep it compact.[/QUOTE] OK I was thinking along the same lines about the download circuit, after reading the manuals again. I have a schematic of the circuit but don't know how to put it on here. I have tried using the program with the servo physically disconnected (as it shares the same power supply as the chip I do have another power supply but it does not share a common ground as recommended in the manuals) and any mention of the servo in the program "rem'd" out.
Just connect the two grounds ( -ve ) together. ONLY the -ve lines.but it does not share a common ground as recommended in the manuals)
I concur. The drawing can be hand drawn if that's all you can manage. It must be complete, though. Then scan or photograph the drawing and post it as a JPG file.I think we need to go right back to the beginning. We need a circuit diagram - go advanced when you submit a reply and have a look at manage attachments at the bottom of the page.
Then post the current program and we can be sure we are all talking about the same thing.
Yes, I can see your circuit diagram. The first thing I noticed is that you have not drawn in the resistor/s between pin C.5 (Serial in for programming) and 0v. As a couple of people including myself have mentioned previously: it won't run without this pin tied low.This is the schematic of my breadboard setup it is a word document. Hopefully I have added it right.
I think an important question is ( on your real hardware with everything connected ); does everything else work as required and as expected, is it only that the lights flash too fast which is the problem ?I have substitued my power supply with a battery pack and that lights still flash rapidly.
#picaxe 14M2
start0:
suspend 1
declare:
' dirsC = %000110
' dirsB = %000011
; PINS
symbol LED1 = C.1
symbol LED2 = C.2
symbol LDRControl = C.4
symbol servoPin = B.1
' symbol bell = C.3
symbol LDR1 = C.0
symbol LDR2 = B.5
symbol LDR3 = B.4
symbol LDR4 = B.3
symbol LDR5 = B.2
; VARIABLES
symbol servoPosition = bit1 ; 1 = raised, 0 = lowered
symbol gatesPosition = bit2 ; 1 = raised, 0 = lowered
symbol LL1 = b7 ; variable to store sensed light level
symbol LL2 = b8 ; variable to store sensed light level
symbol LL3 = b9 ; variable to store sensed light level
symbol LL4 = b10 ; variable to store sensed light level
symbol LL5 = b11 ; variable to store sensed light level
symbol baseLDRLevel = b12 ; store non-interrupted light level for comparison
symbol servoMax = b13 ; maximum raised movement for gates
symbol servoMin = b14 ; maximum lowered movement for gates
symbol flasherspeed = w1 ; LED Flashing speed
; b26 - for loops
; b27 - for loops
; FIXED
symbol timeToFlashStop = 2000 ; delay before flashing stops after gates raised
symbol flasherspeedstatic = 340 ; set speed of lights flashing when gates static
symbol flasherspeedmoving = 345 ; set speed of lights flashing when gates moving
flasherspeed = flasherspeedstatic
symbol delayTillRaise = 2000 ; delay till the gates start to raise after track clear
symbol delayTillLower = 1000 ; delay after flashing starts till the gates start to lower
symbol servospeed = 60 ; set speed of servo
servoMax = 200
servoMin = 120
servoPosition = 1
gatesPosition = 1
servo servoPin, servoMax ; initialise servo to raised state
low LED1 ; initialise flasher leds to off
low LED2
; BOOM CONTROL
READADC LDRControl, baseLDRLevel
READADC LDR1, LL1
READADC LDR2, LL2
READADC LDR3, LL3
READADC LDR4, LL4
READADC LDR5, LL5
baseLDRLevel = baseLDRLevel - 8
if gatesPosition = servoPosition then
if LL1 < baseLDRLevel or LL2 < baseLDRLevel or _
LL3 < baseLDRLevel or LL4 < baseLDRLevel or _
LL5 < baseLDRLevel and gatesPosition = 1 then
gatesPosition = 0 ; gates lowered
gosub lowerGates
sertxd ("here 2", 13, 10)
elseif LL1 >= baseLDRLevel and LL2 >= baseLDRLevel and _
LL3 >= baseLDRLevel and LL4 >= baseLDRLevel and _
LL5 >= baseLDRLevel and gatesPosition = 0 then
gatesPosition = 1 ; gates raised
gosub raiseGates
sertxd ("here 3", 13, 10)
; sertxd ("Active Point, ", #baseLDRLevel, " - ")
; sertxd ("ADC, ", #LL1, ", ", #LL2, ", ", #LL3, ", ", #LL4, ", ", #LL5, 13, 10)
lowerGates:
; sertxd ("Lowering Gates",13,10)
restart 1
pause delayTillRaise
flasherspeed = flasherspeedmoving
for b27 = servoMax to servoMin step -1
servopos servoPin, b27
pause servospeed
next b27
servoPosition = 0
raiseGates:
; sertxd ("Raising Gates",13,10)
pause delayTillLower
for b27 = servoMin to servoMax
pause servospeed
next b27
servoPosition = 1
pause timeToFlashStop
suspend 1
low LED1
low LED2
' low bell
start1: ; LIGHT CONTROL
' toggle bell
toggle LED2
pause flasherspeed
toggle LED1
toggle LED2
pause flasherspeed
start:
readadc c.0,right
GoSub ChangeLights
'GOSub BoomDown
GoSub ChangeLights
readadc c.0,right
If b4 =5 Then
GoSub ChangeLights
b4 = 0
end if
inc b4
readadc c.0,right
if b4 =5 Then
GoSub ChangeLights
b4 = 0
end if
inc b4
end if
if right>150 then
readadc c.4,left
if b4 =5 Then
GoSub ChangeLights
b4 = 0
end if
inc b4
loop while left<150
readadc c.4,left
if b4 =5 Then
GoSub ChangeLights
b4 = 0
end if
inc b4
loop while left>150
GoSub ChangeLights
'GoSub BoomUp
GoTo start
end if
GoTo Start
if b5 = 0 then
low B.1
high B.2
low B.2
High B.1
high B.1
low B.2
high B.2
low B.1
b5 = b5 XOR 1
'BoomUp:
'servo B.4,150 ;set servos at 150
'servo B.5,150
'for countr = 140 to 225
'servo B.4,countr
'servo B.5,countr
'servo B.5, countr
'if b4=5 Then
' GoSub ChangeLights
' b4=0
' end if
'pause 1
'next countr ;increment counter by one count
'Return
'BoomDown:
'servo b.4,225 ;set servos at 225
'servo b.5,225
'for countr = 225 to 140 step -1
'servo b.4,countr
'servo b.5,countr
'servo B.5,countr
'if b4=5 Then
'GoSub ChangeLights
'b4=0
'end if
'pause 1
'next countr ;decrement by one count
'Return
My using Logicator as a training aid is exactly what I am doing, but with the level of programming I am aspiring to it probably would suffice..Opinion: Majoring in Logicator flow charts rather than Baisc code will effectively paint you into a corner and reduce the number of members of this forum can effectively give you meaningful support.
Good to be able to read and produce a flow chart, but the implementation is unable to fully exploit the full command set of the PICAXE Basic language.
A picture may be worth a thousand words, but I suggest that your efforts would be better spent learning to read code. Create a few small programs with Logicator, translate to Basic and study the correspondence between the two. It will come fairly quickly and practice makes perfect.
Basic is also free to use and likely to allow you to write longer and more complicated programs than you would be able to achieve using Logicator.
I may be well out of line, but I would consider Logicator to be a very good trainer, but not a real programming tool. Not that GUI programming aids are necessarily bad, but they take a lot more work on the part of the designers to produce a good end result. Invariably it becomes a compromise and offers reduced facility over the standard Basic code option of using the PICAXE Program Editor suite.
