Picaxe 18 Tutorial Board AXE050U
hal8000
I bought a Picaxe 18 tutorial board, some months ago, just started using it.
Mine has the older Picaxe18 chip installed.
On the tutorial board are 3 push switches, 1 LDR and a 7 segment LED display.
I've just checked through the PDF manual but cannot find which pins of the
Picaxe18 connect to which hardware.
I had a look at the pdf file:
http://www.picaxe.com/docs/axe050.pdf
Which does list LDR is connected to pin 2 permanently, but did not see where
switches are connected.
I can get a magnifying glass and phsically trace the PCB tracks, but is there
a schematic anywhere (online or pdf file) that would make this easier.
Sorry if I missed this, thanks in advance.
hal8000
Thanks a lot, any idea of the order of the pins of the 7 segement display?
The manual says the display is connected to all outputs, so I could
just send an output to each pin in turn.
Have a look at the top of the actual physical board. All inputs/outputs are actually marked - for the 7 seg see the number pattern directly under the actual physical display.
Welcome to the PICAXE forum.
For the 7-seg display you can also try some deductive skills.
Look at the program code in Tutorial 7 (page 25) of the AXE050 datasheet you linked to in Post 1.
The Let pins = statements are driving the display through the outputs.
There are also words in the datasheet indicating the Decimal point is on output 7.
Read about "pins" in PICAXE manual 2 on page 138.
