Icarus,
this is merely a suggestion.
If space permits then consider a SOIC to DIP adaptor.
Then you can breadboard it. Also as it is a pukka PCB there is solder-resist in between the legs. This makes a successful solder more likely.
I don't want to prompt 3000 replies saying "I can solder SOICs 'cos I'm so clever" as that is very boring, but for prototyping/practicing/breadboarding those little adaptors can be handy.
Also, if you solder the SOIC onto a home-brew PCB and you've messed up the board then getting it off again without overheating can be a chore.
If it's on a separate plug-in then it can help.
Co-incidentally, exactly that scenario happened to me last week. And it
did help
They are available very cheaply (Futurlec??) or very dearly (RS and farnell). All I will say about one of the versions available from RS is that the pins are very thin and will plop into DIP sockets without damage.
