Help with family 14M
fizeu6
that I can not send a pin output 3 and 5 of the family 14M. When I reviewed mark syntax error.
example of the program.
high 3
pause 500
low 3
pause 250
if someone can help me thanks
From jalisco mexico.
ylp88
Which version of Programming Editor are you using? According to the revision history, version 5.1.5 "updated 14M firmware compiler error messages".
I'm running 5.2.0 and don't have any problems in the sytax check for the code ssample you provided.
ylp88
fizeu6
do you have the Programming Editor set to the 14M.
If you are unsure, have a look at menu VIEW / OPTIONS
Josh,
Believe you are confusing the 14M (whihch has Input 3 and output 3) with the 08M where IO pin3 is only usable as an input.
