Best Stepper Motor Commands
eclectic
Thank you Westaust55.
Much easier to achieve than my slower method.
b1 = 10
W1 = 5000
CWise:
pulsout 1,w1:pause b1
pulsout 2,w1:pause b1
pulsout 3,w1:pause b1
pulsout 4,w1:pause b1
CounterC:
But, I should have remembered the obvious first step
at the start of the program.
setfreq m8
Duuuh
e
mikemwa
OK. I was using the pulseout but even fast didn't seem fast enough. I tried let pins again and this time it worked. I didn't realized that before I was using pins 1,2,3 and 4instead of pins 0,1,2,and 3. I just started to write the program and haven't had a chance to check this much out yet. This is what I've done so far.
;Forum Mikewma 190108
#picaxe 20M
b3 = 100			'long pause
b4 = 10			'short pause
b5 = 2			'move .002" for surface reading
b6 = 30			'move to minimum spec.    .030"
b7 = 33			'move a couple thousanths short of average reading   .033"
b8 = 34			'move another thousanth   .034"
b9 = 35			'move to average reading  .035"
b10 = 36			'move another thousanth   .036"
b11 = 37			'move another thousanth    037"
b12 = 50			'move to maximum spec.    .050"
'This section is used to manually posision the micrometer
If pin1 =1 then 		'move in reverse slow
gosub CounterC
pause b3
If pin2 =1 then 		'move in reverse fast
gosub CounterC
pause b4
If pin3 =1 then 		'move forward slow
gosub CWise
pause b3
If pin4 =1 then 		'move forward fast
gosub CWise
pause b4
'This section runs the sequence for the Micrometer.
'After it moves to one position it waits for a signal
'then moves to the next position etc.
'Using a switch for the signal for right now
If pin5 =1 then
for b0 = 0 to 5
lookup b0, (b5, b6, b7, b8, b9, b10, b11, b12),W1
;type in the 6 values you need
for b1 = 1 to W1
gosub CWise
next
next
CWise:
let pins = %11000
pause b4
let pins = %01100
pause b4
let pins = %00110
pause b4
let pins = %10010
pause b4
CounterC:
let pins = %11000
pause b4
let pins = %10010
pause b4
let pins = %00110
pause b4
let pins = %01100
pause b4
Let me know if this is doable or you think I should still use the pulseout. Thanks.
eclectic
Very quick first reply
This line
lookup b0, (2,30,33,34,35,50),W1
will interfere/overwrite your b3 value
In the manual reference I gave earlier, you'll see
b0 + b1 = W0
b2 + b3 = W1
try changing W1 to b2
I haven't had time to look at the rest.
e
mikemwa
OK, if Let Pins will work will the lookup work or is there a better way to do that.
In the sequence it needs to wait for a signal before it moves to the next variable.
after it moves to one position it waits for a signal then moves to the next position etc.
I revised the code in post 42 a little to show you what I mean.
b1 = 10
W1 = 5000
setfreq m8
Duuuh
e
eclectic, no far from a Duuh moment.
I had also thought about that option, but:
1. It only allows a 2:1 speed ratio - wondered if that is what is required.
2. when changing from 4MHz to 8MHz, although the manual does not mention any impact from clock speed change for READADC commands, I wonder if the necessary bits ADCS1 and ADCS0 in SFR ADCON0 ($1F) are changed in line with the datasheet to keep the ADC conversions optimal.
Guess some peeks while using SETFREQ will verify that by looking at bits 6 and 7.
eclectic
@mikemwa
I've found a 6 wire unipolar, which I've wired as a bipolar.
I copied the Bipolar/L293 circuit from manual 3. (outputs 4 -7)
My motor's 48 steps, but the principle are similar.
I've changed a few lines/values in your program (******)
It's working.
e
#picaxe 20M
gosub CounterC
pause b3
gosub CounterC
pause b4
gosub CWise
pause b3
gosub CWise
pause b4
If pin5 =1 then
for b0 = 0 to 7 ;****** for 8 values
lookup b0, (b5, b6, b7, b8, b9, b10, b11, b12),b2 ;***
for b1 = 1 to b2;***
gosub CWise
next
next
CWise:
pins = %01100000 : pause 3 ;4
pins = %01010000 : pause 3 ;3
pins = %10010000 : pause 3 ;2
pins = %10100000 : pause 3 ;1
CounterC:
Added 15.20 GMT
I inserted the line
symbol pslen = 1000
then changed CW CCw to
CWise:
pulsout 4, pslen
pulsout 6, pslen
pulsout 5, pslen
pulsout 7, pslen
CounterC:
pulsout 7, pslen
pulsout 5, pslen
pulsout 6, pslen
pulsout 4, pslen
Works fine as well.
I haven't done any timing tests.
mikemwa
Eclectic,
I tried your program. At first it wasn't working. I had to change the let pins. I see you just used different pins than I did. Anyway it still didn't run quite right for some reason.
I've been working on the code and below is what seems to work good for pins 1-4 for the positioning.
The problem starts when I push the button on pin 5 to start the sequence. From that point on it won't work. Also from that point on I know the code is a mess. I've tried different things.
A push button has been added on pin 6 to simulate the signal from the machine this will be attached to.
The other problem is I'm running out of memory. I don't know how to condense this so it will take less memory like you do. (I'm learning slowly but surely) If you could guide me in doing that it would be nice.
At this point timing is no problem I can figure that out when I get this thing working.
It's getting so close.
#picaxe 20M
b3 = 2500			'long pause
b4 = 5			'short pause
'b10 = 36			'move another thousanth   .036"
'b11 = 37			'move another thousanth    037"
gosub CounterCs
'pause b3
gosub CounterCf
'pause b4
gosub CWises
'pause b3
gosub CWisef
'pause b4
If pin5 =1 then goto sequstart
'for b0 = 0 to 5
'lookup b0, (b5, b6, b7, b8, b9, b10, b11, b12),W1
'type in the 6 values you need
'for b1 = 1 to W1
'gosub CWisef
'next
'next			'syntax error
'endif		'syntax error
CWises:
let pins = %00011000
pause b3
let pins = %00001100
pause b3
let pins = %00000110
pause b3
let pins = %00010010
pause b3
CounterCs:
pause b3
pause b3
pause b3
pause b3
CWisef:
pause b4
pause b4
pause b4
pause b4
CounterCf:
pause b4
pause b4
pause b4
pause b4
'problems starting here
sequstart:
for b13=1 to 50
for b2=1 to b5
pulsout 1,1000:pause 100
pulsout 2,1000:pause 100
pulsout 3,1000:pause 100
pulsout 4,1000:pause 100
next b2
next b13
If pin6 =1 then goto Minspec
Minspec:
for b13=1 to 50
for b2=1 to b6
next b2
next b13
If pin6 =1 then goto fstchk
fstchk:
for b13=1 to 50
for b2=1 to b7
next b2
next b13
If pin6 =1 then goto avgchk
avgchk:
for b13=1 to 50
for b2=1 to b8
next b2
next b13
'If pin6 =1 then goto maxspec
'maxspec:
'for b13=1 to 50
'for b2=1 to b8
'pulsout 1,1000:pause 100
'next b2
'next b13
'If pin6 =1 then goto main
eclectic
@mikemwa
This is becoming difficult for me, because your program
and your requirements keep changing.
I'll have another go.
First, just use two move routines. One CW and one Ccw
Change the delay times outside the routines.
Sequstart.
Here, for instance
next b13
Minspec:
The code will move to the next line automatically.
It will not wait for a button press. You need a loop.
Let's build on an original program.
Please try the following cut-down code on your setup.
Does it work?
Does it need adjusting?
;Forum Mikewma4 220108
#picaxe 20M
symbol longdel  = 2500	'long pause
symbol shortdel = 5	'short pause
gosub CounterC
pause longdel
gosub CounterC
pause shortdel
gosub CWise
pause longdel
gosub CWise
pause shortdel
If pin5 =1 then
goto sequstart
CWise:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
CounterC:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
sequstart:
for b0 = 0 to 4
lookup b0, (b5, b6, b7, b8, b9),b1
W1= b1*50
for W6 = 1 to W1
gosub CWise
next
Do
Loop until pin6 = 1
next
e
mikemwa
The code you posted worked OK. I changed the timing and added the other positions in and it is actually working pretty good now but not perfect.
Things I changed have '***** in the comment line.
#picaxe 20M
symbol longdel  = 100	'long pause
b5 = 2		'*****	'move .002" for surface reading
b6 = 28		'*****	'move to minimum spec.    .030"
b7 = 3		'*****	'move a couple thousandths short of average reading   .033"
b8 = 1		'*****	'move another thousandth   .034"
b9 = 1		'*****	'move to average reading  .035"
b10 = 1		'*****	'move another thousandth   .036"
b11 = 1		'*****	'move another thousandth    037"
b12 = 13		'*****	'move to maximum spec.    .050"
'This section is used to manually position the micrometer
gosub CounterC
pause longdel
gosub CounterC
pause shortdel
gosub CWise
pause longdel
gosub CWise
pause shortdel
If pin5 =1 then
goto sequstart
CWise:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
CounterC:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
sequstart:
for b0 = 0 to 7	'*****
lookup b0, (b5, b6, b7, b8, b9, b10, b11, b12),b1	'*****
W1= b1*6	'*****
for W6 = 1 to W1
gosub CWise
next
Do
Loop until pin6 = 1
next
Manual positioning works and the sequstart: section works as far as when I push the button on pin 6 it will move to the next position.
I only see 2 issues left.
1. When I press the button on pin 6 sometimes it will continue for 2 or 3 positions. Sometimes these movements are very short. I should be able to fix that with a pause somewhere right?
2. The micrometer isn't moving to the right position.
Some Information:
Post # 35 shows my setup.
Stepper motor - 200 steps per revolution.
Ratio - 1 on stepper and 5 on micrometer.
One rotation of the micrometer handle moves it 0.0200 inch. (1000 Steps on the motor)
This is what it should do This is what it's doing
Should Steps Is Steps
Move to on Moving Moving
Position Motor Now Now
0.0020 100 0.0009 45
0.0300 1500 0.0143 750
0.0330 1650 0.0157 785
0.0340 1700 0.0162 810
0.0350 1750 0.0167 835
0.0360 1800 0.0172 860
0.0370 1850 0.0177 885
0.0500 2500 0.0211 1055
Seems to be more than 50% off.
I'm pretty sure these figures are correct. I will double check when I get home.
eclectic
2 immediate responses
sequstart:
W1= b1*6	'*****
for W6 = 1 to W1
gosub CWise
next
Do
Loop until pin6 = 1
next
1. Add a Pause 1000 after the loop until line.
2. You are over-writing the value of b12 when you use W6.
I'll try and have a look later today.
e
eclectic
I've done some modifications.
NB
I've included code for MY motor. Please remove.
I've also made other modifications to variables.
Please can you test it "as is"
and let me know.
e
;POSTED on forum Gr 230101
 ;ALTERED
#picaxe 20M
symbol plslen = 500 ; ****************************remove
b6 = 2		'*****	'move .002" for surface reading
b7 = 28		'*****	'move to minimum spec.    .030"
b8 = 3		'*****	'move a couple thousandths short of average reading   .033"
b9 = 1		'*****	'move another thousandth   .034"
b10 = 1		'*****	'move to average reading  .035"
b11 = 1		'*****	'move another thousandth   .036"
b12 = 1		'*****	'move another thousandth    037"
b13 = 13		'*****	'move to maximum spec.    .050"
gosub CounterC
pause longdel
gosub CounterC
pause shortdel
gosub CWise
pause longdel
gosub CWise
pause shortdel
If pin5 =1 then
goto sequstart
CounterC:; ****************************** Take out my code
pulsout 7, plslen
pulsout 4, plslen
pulsout 6, plslen
pulsout 5, plslen
CWise:
pulsout 7, plslen
pulsout 5, plslen
pulsout 6, plslen
pulsout 4, plslen
#rem
;*********************************** Put YOUR code back in
CWise:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
CounterC:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
#endrem
sequstart:
for b0 = 0 to 7
lookup b0, ( b6, b7, b8, b9, b10, b11,b12,b13),W2	'***** W2
W2= W2 *6	'*****
for W1 = 1 to W2
sertxd (#w1," ")
gosub CWise
next
Do
Loop until pin6 = 1
pause 500 ; allow for switch bounce
next
e
mikemwa
The Position tests are the same as before unless I didn't do somethiing you wanted me to do. Heres what I did.
 ;ALTERED
#picaxe 20M
gosub CounterC
pause longdel
gosub CounterC
pause shortdel
gosub CWise
pause longdel
gosub CWise
pause shortdel
If pin5 =1 then
goto sequstart
#rem
pulsout 7, plslen
pulsout 4, plslen
pulsout 6, plslen
pulsout 5, plslen
CWise:
pulsout 7, plslen
pulsout 5, plslen
pulsout 6, plslen
pulsout 4, plslen
#endrem
CWise:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
CounterC:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
sequstart:
for b0 = 0 to 7
W2= W2 *6	'*****
for W1 = 1 to W2
sertxd (#w1," ")
gosub CWise
next
Do
Loop until pin6 = 1
next
eclectic
Thanks for your reply
OK, this is a test of the Stepper.
I'm interested to see its behaviour.
1. Attach a "marker" to your stepper.
2. Record the Mic' reading.
3. Try the program.
; First, check the start position
; on the stepper AND the Mic'
for b0 = 1 to 200
gosub CWise
next
; then repeat the program, but using CounterC
stop
CWise:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
CounterC:
pause shortdel
pause shortdel
pause shortdel
pause shortdel
Big questions.
Q1. Does 200 Program steps = exactly ONE stepper-revolution?
Q2. How much does the Mic' change in 200 program steps?
e
mikemwa
The motor makes 4 complete revolutions.
The Mic reads 0.0160
The Mic needs 5 revolutions of the motor for it to go to 0.0200
eclectic
Thanks. Looks like some simple maths and gearing calculations. (Famous last ... )
Then, a re-hash of some of the software variables.
Calculator time?
Back tomorrow (Brit) evening.
e
BCJKiwi
That figures,
motor = 200 steps per rev,
gearing = 5:1
1000 motor steps required for one rev of Micrometer
5000 motor steps required for 5 revs of Mic = 0.0200
Currently doing 4/5ths of what you wnat so change
for b0 = 1 to 200
to
for b0 = 1 to 250
eclectic
Tired,
but, each "thou" = 1.25 stepper steps.
(it's been years since I've tried to think in "thous")
Look what I found in the shed.
A rare Imperial / Metric Shardlow.
(No comments Dippy.) :)
e
mikemwa
Changing:
for b0 = 1 to 200
to
for b0 = 1 to 250
Does work for this Mic
This got me thinking:
This Mic at home is 1 revolution = 0.0200"
The one at work which is what this will ultimately go on might be 1 revolution = 0.0250"
I will have to check for sure when I get to work tonight.
If possible what would the changes be to the code on both Mic's so I could use it on this one also.
BCJKiwi
Mike,
you need to understand the relationship and do the calcs, then you can change the code to suit whatever you need.
The critical piece of info is steps per thou or mm or whatever base the measurement is.
As discussed (post #59) - Setup @ Home
Motor = 200 steps per rev,
Drive ratio = 5:1
As the 0.0200 is 20 thou", then 5000 / 20 = 250 steps per thou
If the unit @ work is 5000 steps for 25 thou, then 5000 / 25 = 200 steps per thou.
So the number eclectic started with of a loop of 200 would suit the work mic (if it's at 25 thou per rev).
Interestingly, the 0-25mm vernier graduated manual micrometer I have has a barrel thread pitch of 0.5mm (= 0.0197" - i.e. basically the same as your mic @ home with 0.020"). It also has 50 divisions around the barrel and 10ths of that on the vernier for a final resolution on the vernier marks of 0.001mm ~ 4/10ths of a thou"
eclectic
Mikemwa.
A slightly altered viewpoint. Currency exchange.
For your original micrometer setup,
How many gosubs make a thou' ?
From post# 56
200 gosubs makes 4 complete motor revolutions.
The Mic' reads 0.0160
So 200 gosubs is worth 16 thou'
50 gosubs = 4 thou' and finally,
1 thou' is worth 12.5 gosubs.
Next, try this alteration to the most recent program.
for b0 = 0 to 7
lookup b0, ( b6, b7, b8, b9, b10, b11,b12,b13),b1
W2= b1*25 ; new "currency exchange
W2 = W2/2 ;	new "currency exchange
for W1 = 1 to W2
sertxd (#w1," ") ; remove after test
gosub CWise
next
It will NOT be perfect metrology, but, what is your allowed tolerance?
(In old Brit, how big are the Gnats?)
For your second micrometer,
1 motor rev. is worth 5 thou', so
1 thou' is worth 10 gosubs.
Any mistakes are the result of me rushing a reply.
Please test first.
Then let me know.
e
mikemwa
Eclectic,
As far as the gosubs, it goes like this.
Length....Gosubs........Difference
.001...........13.................13
.002...........25.................12
.003...........38.................13
.004...........51.................13
.005...........63.................12
.006...........76.................13
.007...........88.................12
After inserting your code it’s darn near perfect. This is what I am getting.
Should be.....Is
.0020.........0020
.0300.........0299
.0330.........0329
.0340.........0339
.0350.........0348
.0360.........0358
.0370.........0368
.0500.........0497
Being off .0003 out of .0500 is good in my book. There could possibly be other reasons for that. I don’t think you could get much closer.
Mike
eclectic
Thanks for the reply and the fast testing.
The gnats are reasonable in your area.
If you go to the other Mic', the the errors may
be reduced.
Keep experimenting. :)
e
mikemwa
Well thank you Eclectic and everyone else for all your help. I really appreciate it. Now all I have to do is get it on a circuit board, in a box and on the machine (hoping I don't blow it up) and see what happens.
eclectic
Mike.
A possible improvement.
If none of the values b6 – b13 ever exceed ~ 250,
then please try this and see what happens.
for b0 = 0 to 7
W2= b1*250 ; new 2"currency exchange
W2 = W2/20 ;     new 2 "currency exchange
for W1 = 1 to W2
gosub CWise
e
mikemwa
2 thoughts
1. Does it matter in what position Let pins start matter?
2. Is it possible to increment 1 Let Pins line so many times with a variable?
Just curious if that would be another way to do it. Like I say It's darn near perfect now and when I get everything solid that small error might go away.
eclectic
2 thoughts
Just write some little test programs,
and see if there are any differences.
Or if it works at all.
e
eclectic
Mike.
There's another possibility.
See here for the explanation and diagrams/animation.
http://www.doc.ic.ac.uk/~ih/doc/stepper/control2/sequence.html
Look at the differences between
Single coil
2 coil (Which you are using).
Interleaving / half step.
However, rather than get into more complexities,
may I suggest using what you have for the moment.
When it's all bolted together properly, test it.
If it's good enough, then just leave it.
If not, then possibly half-step time?
Next. Referring to the circuit in your post #13.
I strongly suggest that you include the full download circuit,
along with a 3mm stereo socket.
You WILL want to alter the programming, sometime.
And possibly finally, a RED, all-off, toggle switch, just in case. :)
e
mikemwa
I have that site bookmarked. Lots of good info there.
When things are finished I will see if I need to change things or not.
I was planning on including the download circuit. Those variables b6-b13 will be changing constantly probably 15-20 times a day. I hope the Picaxe isn't too limited as far as how many times it can be changed.
I will also have an on/off switch for the whole thing. I have attached a file showing what my panel is going to look like. Is there anything else I might need?
eclectic
Suggestions?
1. Build the unit in "modules" which can be re-used and moved around.
Use plug-in / cable / other system.
2. Test it thoroughly.
3. Plan for a Mark II version.
If you're going to change 8 variables 20 times a day, you'll be better off with
a LC display and a button entry menu.
But, that's for the future.
e
The PICAXE variable b0 to b13 (and onward for X1/X2 parts) are stored in RAM memory and so have no limitation on the number of time they can be written to.
Only EEPROM memory has a limitation of around 100,000 writes per location but an infinite number of reads per memory location.
mikemwa
Eclectic,
Sometimes you and I think alike:). Since getting those other problems fixed I have been working on the box and am starting on the circuit.I have about 5 cables/connectors and am trying to separate things into 1. power supply section, 2. chip section, and 3. LED/switch section.
There are probably 30-40 different parts and specs. that we test on a regular basis. I was trying to figure out a way to do that more automatically and faster but I wasn't sure what the capabilities of the Picaxe were. Plus I have no idea how to work with and program an LCD display at this time. But I'll cross that bridge when I come to it.
Westaust55,
That's good to know. At least I won't have to change chips all the time.
eclectic
" Plus I have no idea how to work with and program an LCD display at this time.
But I'll cross that bridge when I come to it."
Actually, that's probably the easiest part!
Rev-Ed sell an excellent and simple serial display called the AXE033.
Plenty of references on the forum.
Plus, there are USA versions, but I haven't any experience of these.
For the future, it may be worth investing in the 28X1 chip.
Lots more inputs, variables and memory.
e
mikemwa
That's really good to know. I do have the 28X1. When I first got into this I got the 08M, 20M, 18X and 28X1 starter kits. I wanted to save on shipping and I knew if I liked this and could do it I would be getting them anyway.
I have only assembled and worked with the o8M and the 20M so far.
I took a quick look and didn't see any vendors in the U.S. but will look more later. Maybe someone in this forum knows where I can get one.
Will the AXE033 work with the 20M?
Can't advise on US suppliers but the AXE033 will work with ANY PICAXE in serial mode. It must be an "X" type if you want to use it I2C mode.
eclectic
Now that's being well prepared! :)
As far as the 20M / AXE033 goes, then yes.
All Picaxe chips can do "serout" (manual 2 page158)
(Don't worry about the details yet).
And, I'll whisper this quietly.
Perhaps post a new thread,
asking US picaxers to suggest a serial LCD that works easily with Picaxe.
But don't tell anyone I told ya. :)
e
