Thank you Hippy forr the fast responce,
but Yesterday I was searching the net and found the following PDF. It seems that a "seconds" pulse can be taken directly from the sqw output on the zs-042 after reprograming the output.
In the case as described in the pdf it is done with an Arduino, but is this also possible with a picaxe and how? It seems that it needs only reprogramming the zs-042 once to set the sqw output to 1Hz. This way I need only 1 + grnd pin input on the picaxe instead of 2 for the I2C wires.
Here is the PDF. the 2 last blocks are relevant. I could not coppy/past them.
http://www.rinkydinkelectronics.com/resource/DS3231/DS3231.pdf
If the above is at all posible, Could you help me with this pls?
Sorry for my english, i can not always write it as i like to.
Willy
