The circuit is supposed to:
1. Induce some waveform through the Toroidal windings from the Mosfet pulsed 12V onto the 150V dc passing through the load. The Toroid "primary" (left side on schematic) is 43 turns 20AWG wire. The "secondary" (with 150V on it) is 133 turns of 16AWG wire, so roughly 1:3 ratio.
The 2.1uH "heavy duty" chokes are asked for in the original circuit, I suppose to handle spikes etc. ?
My question:
Within the elipse there are 2x resistors as voltage divider and 1x Capacitor across the clamping diode (mosfet protection diode).
1. Will the cap have ANY benefit when placed there ? If it will, what sort of value will be required ?
2. The voltage divider will bias the Mosfet gate to +- 1.95V from the 15V supply. The idea is to keep the Mosfet just below the Gate Threshold voltage which normally starts at +- 2V minimum. Does have any value/benefit ? Quicker Gate charge time maybe ? The TC4420 has built-in totem pole so switch-off should still be quick.
3. Does ANY of this part of the circuit have ANY value ? If it has, kindly explain in short why.
Many thanks for your time
Manie
My question:
Manie
