Here is some specs on the 18M2 do out in July 2010
It will also replace ALL of the 18xxx chip's
http://elecurls.tripod.com/picaxe-sum.htm
-teddy
@teddy,
Ya gotta keep up man!
Post 5 gave the Rev Ed flyer will lots of information
Post 64 gave the July 2010 date.
The data at the link you gave is missing a lot of data and has some errors.
40X1 is 5V rated not 3V (but can work down to 2V at 4/8MHz).
X1 and X2 parts Absolute Maximum current capabilities are:
Total for chip == 95mA
Total ofr all ports is 90mA
Max for one IO = 25mA
Statement made is:
“* = DO NOT leave Input PINS "floating". Use a 4.7k Resistor to Terminate to Ground, or pull them High with a 4.7k Resistor to VDC+”
It is not mandatory to tie unused inputs to ground or Vcc but there may be circumstances where doing so may help with things such as reduced power consumption, etc.
Statement made is:
“** = If Serin or Serout are NOT being used, Terminate them with a 100k Resistor to Ground”
Yes the SERIN line must be pulled to ground – recommended is 10 kOhm but 100k should do.
Absolutely no need to pull SEROUT line to ground.
But keep up the work and complete/correct your table and it will be useful
