hi, i am relitivly new to picaxe and have only just found this forum. i have used picaxe for my previouse project, a water irrigation system, i am now using the XBEE wirless boards.
I have soldered all the components on both boards, the problem i am having is the initial setup procedure, i follow the steps in the data sheet and the first time it worked no problem and the ping test also worked to show the two boards were communicating, but every time since i set the XBEE baud rate and click write to configure the settings it says no response, also when i click read version it says no response.
I also tried sending data from one board to another and in the terminal window it was displayed as symbols rather than number.
was wondering if anyone has any ideas what could be the problem.
thanks
sean
thanks
sean
