Blazemaguire
I'm doing a small RFID project using the 125mhz serial RFID readers of ebay. Got the reader working fine and it spits out 10 numbers which I'm storing in ten variables (B0,b1,b2,b3,b4,b5,b6,b7,b8,b9) - for simplicity, I'm not showing that part of the code as it works fine
How can I store all of these into consecutive EEPROM locations (i.e, EEPROM, b0,b1,b2,b3,b4,b5,b6,b7,b8,b9) and then, when the next scan occurs, store the next 10 variables in b0 through b9 into the next 10 eeprom slots (b10,b11,b12,b13,b14,b16,b16,b17,b18)?
I've tried this:
This just seems to overwrite each EEPROM location with all ten variables, resulting in only the final variable actually being stored in each EEPROM slotafter all is said and done.
I can't seem to figure out how to phrase this code correctly (I'm still learning!)
At the moment I'm have to do the below to store and read the EEPROM... but this only works for the first 10 digit code recorded, and I can't wrap my head around how to amend this so the next fob I scan goes into locations, 10 through 19. Also, it seems a very clunky way of doing it.
Any suggestions or pointers? thanks!
I've tried this:
'This code assumes the ten numbers have already been read into the ten variables b0 through to b9
symbol start_pointer=b10
symbol finish_pointer=b11
symbol eeprom_location=b12
start_pointer=0 'start at memory location 0
finish_pointer=9 'end 10 places later so
Scan_Keyfobs:
for eeprom_location = start_pointer to finish_pointer 'for memory location 'start' to 'finish' i.e, 0 to 9, then 10 to 19, then 20 to 29 etc
write eeprom_location,b0,b1,b2,b3,b4,b5,b6,b7,b8,b9
next eeprom_location
start_pointer=start_pointer+10 'adds ten to the position counter start
finish_pointer=finish_pointer+10 'adds ten to the position counter end for the for loop
goto scan_keyfobs
write b0,b0
write b1,b1
write b2,b2
write b3,b3
write b4,b4
write b5,b5
write b6,b6
write b7,b7
write b8,b8
write b9,b9
