Hi. I have been playing around with the RXB1 and TXC1 wireless receiver and transmitter from Jaycar. I have also made a program to send a signal to my picaxe to switch on the motors etc. The program definitely works because when I have the serial cable from my computer directly connected to the picaxe input it will do what it is supposed to. Normally if I just have the receiver connected to 5V (and not connected to the picaxe) it can receive signals and the voltage between the receiver ground and data goes up to about 4V (which should be a logic 1). However, as soon as I plug the data pin on the receiver into the picaxe input and the ground from the receiver into the picaxe ground the voltage level between ground and data on the receiver goes right down to 0.12V (which is nowhere near a logic 1).
Does anyone know what is causing this and how to fix it? I am not an expert at electronics or anything so it is probably something stupid that I have missed.
