Hi guys,
I have a stash of 18X8Ms and various other components, that I though I'd use for a home monitoring system. My only requirement is, that communication between sensors and receiver should be wireless (ie 434MHz based).
My idea is the following:
I'll build a range of "dummy" sensor units with the various sensors (temp, moist, etc) and a 434MHz transmitter. Each unit will have an ID and at a given interval - by deafult once every (15 minute + unit id in seconds) to prevent clash of transmissions - each unit will transmit the collected data in sequences of three - inspired by another application found in this forum, to make sure data is received. The transmitter is planned to be of this type: http://www.sparkfun.com/commerce/product_info.php?products_id=8946
On the receiving end, I'll have an 18X8M unit with one (or maybe two if I can find some reason) of these: http://www.sparkfun.com/commerce/product_info.php?products_id=8949. The unit will be attached to a PC onto which the transmitted data will be dumped.
Does this sound as a plausible solution? Should I approach this in a different manner?
Best regards,
Casper Helenius,
Denmark
Best regards,
Casper Helenius,
Denmark
