I've installed Windows 7, its actually very impressive up to yet, running everything faster than Vista and XP, even when taking into account that its a clean install. I've had fewer driver problems that with any other OS (even my illusive wireless card was working DURING the install
) though it isn't quite perfect (that wonderful "unknown device", its not just windows 7 that can't work it out
Anyway onto PICAXE, I've done a few tests on the Programming Editor and everything appears to be working including simulation across every chip I've tried, though my tests are hardly conclusive. The USB010 driver is working with an 08M on a breadboard, I'll test a 28X2 and WinAXEpad shortly.
Any other tests that you'd be interested in the results of?
EDIT: The only code that I have tested is below (I have also tested versions ported to X2s in the simulator), feel free to post any code containing potentially problematic commands for me to test.
#PICAXE 08M
setfreq m8
symbol LED = 2
toggle LED
