UART in 28X1 PICAXE
Have a look at the PIC datasheet for the 28X1/40X1 at page 151
description there for the:
"Enhanced Universal Synchronous Asynchronous Receiver Transmitter (EUSART)"
For the 28X1, physical pins 17 (TX) and 18 (RX) as used by the HSERIN and HSEROUT commands
HSERIN:
Function:
Serial input via the hardware serial input pin (format 8 data, no parity, 1 stop).
Information:
The hserin command is used to receive serial data from the fixed hardware serial
input pin of the microcontroller.
HSEROUT:
Function:
Transmit serial data via the hardware serial output pin (8 data bits, no parity, 1
stop bit).
Information:
The hserout command is used to transmit serial data from the fixed hardware
serial output pin of the microcontroller.
