Again, it all depends on your definition of "standard" and all the qualifications you want to add.
The best "standard" is what polarity is carried on an RS232 cable, what comes out/in of the PC, what comes out/in of a 9-way on any RS232 device and what comes out/in of a USB-to-serial cable.
The standard there is Idle-Low / Active-High - That's what all the Rev-Ed USB cables use.
The point is that if someone buys a "standard" USB adapter, let's say from Sparkfun, it will not work with a PICAXE even though it will work with many other micro controllers.
That's a case of
them not being "standard" USB adapters. If they are not Idle-Low / Active-High they will not work with millions of RS232 devices in the market without needing reconfiguration.
It is unfortunate because it should be a non issue and a not a stumblng block to use a PICAXE.
It is a non-issue for anyone buying a standard USB-to-serial cable whether from Rev-Ed, Maplins, Tesco, PC World, Walmart or wherever. It's when people buy USB modules from Sparkfun and others which are configured for direct connection to microcontrollers which do not use RS232 signalling standards that there's a problem.
Rev-Ed USB-to-serial cables are standard RS232 polarity. It is those modules which are not which cause problems Those modules will not interface with any serial device using 9-way D's / RS232 without being re-configured.
Bootnote
The world uses standard RS232 - Voltage may vary but polarity is Idle-Low / Active High.
Any standard USB-to-Serial cable will comply with standard RS232 - Again voltage may vary but polarity is Idle-Low / Active-High. If it were any other way the cables would not work with standard RS232 equipment.
The PICAXE download interface is RS232 polarity compatible. Thus it can be connected directly to a PC serial port or a standard USB-to-Serial cable. This ability is fairly rare for most microcontrollers and is one of the great and attractive features of the PICAXE. It allows a very simple and cheap interface to be used, just two resistors.
Other microcontrollers use an inverted signal because they expect a MAX232 interface to be installed between themselves and RS232. Having to add a MAX232 to every board using that microcontroller adds cost and makes it more difficult for end users to use ( where the PICAXE wins over them ).
With the advent of cheap USB modules which are voltage compatible with the microcontrollers, it was realised that the MAX232 could be done away with and the inversion done in the USB modules. That's why USB modules which connect directly to such microcontrollers have inverted polarity outputs compared to standard USB-to-serial cables. They work with the microcontroller they are designed for but are absolutely useless for connecting to standard RS232 devices unless re-configured for that purpose.
