Where to start (beginner)
Jarubell
Update:
Well I finally had time away from the family, found my soldering iron for the breadboard adapter and gave it a shot. Uploaded (downloaded?) my simple program to the pic and it worked, well, sort of, it does not do the same thing as the simulator but still, I made some progress with my little 08M!
Should the 08M work at the same speed as the simulator?
Thanks guys, I off to find my multimeter! Should be somewhere.
tjetson
Update:
I know you can slow down the simulator, not sure if you can make it go faster than the code would execute on a picaxe though.
Programs running in a PICAXE may be much quicker than when simulated as simulation has to slow execution down so you can see things happening.
lbenson
What differences are you seeing (post your program)?
An 08M may execute around 4000 instructions per second (exclusive of things like PAUSE); the simulator no more than a handfull per second--you need to be able to see what is happening in the simulator.
Jarubell
All I was trying to do is have three leds that with an input will switch to the next LED
setint %01000,%01000
let dirs = %00010111
	if b1 > 3 then number0
	if b1 = 1 then number1
	if b1 = 2 then number2
	if b1 = 3 then number3
interrupt:
	high 0
	if pin3=1 then interrupt
	low 0
	b1=b1+1
number0:
	b1=0
number1:
	let pin1=1
	let pin1=0
number2:
	let pin2=1
	let pin2=0
number3:
	let pin4=1
	let pin4=0
I'm working on it, maybe it's also my wiring.
MartinM57
Just passing by (in a hurry). From the SETINT command in Manual 2...
1) Every program which uses the SETINT command must  have a corresponding interrupt:
sub-procedure (terminated with a return command) at the [B][I]bottom of the program.[/I][/B]
I've often wondered why, and it may or may not be your problem...
The interrupt doesn't have to be at the bottom of the program, though it will usually be placed there, and many will expect it to be there.
The program looks okay to me so perhaps we need a better descriprion of how the speed differs. The program uses "PAUSE 1000" throughout so those are pauses each one second long. Perhaps that's the issue ?
If the switch connected to pin3 doesn't have a pull-down resistor it could be that the hardware input pin is 'latching' and the interrupt is jamming up after the switch is released.
Jarubell
Hippy, I been reading other posts and noticed that you have mentioned pull down resisters more than once. No, I do not have a pull down resistor and when I get another chance, I going to look in the manuals regarding this the next chance I can.
Take a look in PICAXE Manual 3 ( via Help in Programming Editor ). That will show how to wire the switch up.
Jarubell
Hippy, thank you for directing me, I clearly screwed up my wiring and never thought about the switch wiring. Going to try that tonight, well tonight here in Canada.
Very true hippy, but I guess many adhere to the manual (see Manual 2 V6.9 p.181) which clearly states:
Notes:
interrupt: sub-procedure (terminated with a return command) at the bottom of the program.
Jarubell
Hippy, it works great now that I installed the pull-down resistor and now I searching the site here to find out why it is required.
westaust55, I now see what you posted. I did read that but all I took from it was the required "return".
Thanks for everyones help.
ps, my interrupt is now at the end!
Think of it litterally in terms of a mechanical device.
Your switch pulls the input up.
When you turn the switch off, what happens?
If there is nothing to pull it back down, it will just stay there.
In practice, just like in the real world, things are not perfect and just like there is in real life, there will be a breeze blowing. (electrical noise).
If you think of your input like a balloon, with nothing pulling it in any direction, it will float away in a random direction. (that's why a disconnected input is described as floating).
Andrew Cowan
The 10K is to stop it floating. What is the 1000 you mention? If you are refering to the 'PAUSE 1000', it's to debounce the switch.
A
Jarubell
Andrew, I mean the 1k resistor that I installed on the input for the switch.
oh, I had the pause at 1000 just for the simulator, I now have it at 100 and who knows may not even be required with my setup and switch.
Assuming the 1k is in series with the input, then it is to protect the pin if it accidentally becomes an output and the switch is closed.
The 1K serves two purposes - it helps protects the PICAXE input from ESD ( static discharge when you push the switch such as after shuffling over nylon carpet in woolly socks ) and also protects should the PICAXE input become an output and the the switch pushed, which would short it to 0V or 5V.
The 1K may be reduced or left out when prepared to accept the lower protection.
Jarubell
Great Thanks.
I have another simple non picaxe relate question, breadboards. THis breadboard I have has a sticky back and a same sized sheet of metal, what is the metal for?
Also, I starting to look at transistors, just to see how to use them. So I see there is many options, what would I use to just switch a low voltage or do I need to ask my self more questions?
Side note, I picked up a piezo buzzer and it now has become my favorite annoying toy.
lbenson
"The Source" (3 locations in Dartmouth) might have this pack of 15 general purpose NPN transistors for $5.99 (I couldn't find a part number): http://www.thesource.ca/estore/product.aspx?language=en-CA&product=2761617&category=Semi+Conductors/IC's&catalog=Online&tab=1#more
Or this pack of PNPs: http://www.thesource.ca/estore/product.aspx?language=en-CA&product=2761617&category=Semi+Conductors/IC's&catalog=Online&tab=1#more
If you want more specific parts, http://www.futurlec.com has a selection at reasonable prices--but long shipping times to Nova Scotia.
Here is a standard "low-side" switch with a small "signal" (as opposed to "power") NPN transistor, e.g. a 2n3904 or a 2n2222. LED connects to the Collector, 0V to the Emitter, and the picaxe pin to the Base.
                     C   E
+5V-----330R---LED---o   o---0V
                       o
                       | B
picaxe pin----1K-------'
You can find datasheets for various transistors at www.digikey.ca or www.jameco.com or many other places.
Jarubell
Thanks lbenson
I picked up that 15 pack of NPN transistors but since I'm working away from home, I have not had no time to try them.
How about free circuit drawing programs? Do they exist?
James
