Hello,
I am worried that I've roasted my brand new picaxe with too much voltage - but I have conflicting information, so I need to check.
My set up is a macbook, coupled by usb (ver 8.8) to the AxeStack. I'm using MacAxePad to program the pic.
My first question is this - what voltage do I supply to the AxeStack? In the supplied literature, it says I can apply 5-12, so I have a nice 9v pp3 battery attached to the stack. However, I read later on that I should NOT use a pp3 battery (i'm unclear if this is in referenct to the stack or the pic..) - I'm not sure if the stack has inbuilt voltage regulator or not. if not, have I done the wrong thing?
In any case, my set up appears to have died, and I don't know why, so here is the situtation.
The symptom:
it just "suddenly" dissapeared from view of the computer - i.e. Options>port>USB setup finds a usb serial connection, but here's the strange bit: in the "test" box, I can check "high", then go to mode > firmware, and macaxpad reports that it finds firmware (ver 8.8), however, if I check port>test>"disconnected", then go back to mode>firmware, it cannot find the firmware.
Now, when I try to program the pic, I am ALWAYS returned with a "hardware not found" error.
The reason this is strange, is that it WAS working a few minutes earlier - the difference is that I had a new circuit which (possibly?) fried the pic, although if it did so, it did it very quietly.
I don't want to go all the way into town to look for a new pic if I don't have to! Any clues to what is going on?
The symptom:
