I have a problem with a 28X1 program. When I first download the program in to the picaxe the program works perfectly. When I press the reset button the program malfunctions. (I have arest button on the pcb I designed). I resetting the picaxe would cause the program to run again fresh from the begining just like when you download a new program into the device.
What happens differently inside the picaxe when you download a program into the picaxe and when you reset the picaxe?
Update: It seems that even if I download a new program it doesnt run properly, but if I first of all clear hardware memory then download the program it then runs fine..... Im using the 28X1 with a GSM module, the picaxe learns and writes to eeprom the incomming calls number, it then replies to that number with a sms confirming that it learnt the number. Hithertoo I could just use the reset to start the program over again and then call it with a new phone and the device would learn that number which then gives that phone controll over the equipment.
