Well yes, the use of SMD really comes down to SIZE for me, and I would guess, most others too.
If I can use a standard DIL, then I do, but there are times you want things to be as small and compact as possible, and that is where SMD comes into it's own.
Then, you can always mix the two - I have done that before many times - spread the parts out on both sides of the board. Standard parts on the top, SMD on the bottom.
As mentioned, depends on project and requirements, but what I CAN say at this point, is that I am really pleased there is the freedom of choice in that you can select SMD parts if you need/want to use them, unlike some other alternatives.(BASIC stamp being an example of that).
