Craftybytes
As the title says - what commands will be affected if I run my 28X1 on 16Mhz resonator.?
I've had a read of the Picaxe manuals - but am still unsure as to actual commands that will be effected AND what the effect will be.?
For example - can I still use i2cwrite / i2cread commands correctly at 16Mhz clock or do I need to use the 'setfreq M8' command first then do a return to 'setfreq M16' after any relevant code block.?
Or can I even use the 'setfreq' command if I'm using a 16Mhz resonator clock speed.?
Or is it just a case of being more careful of changed 'timings' with respect to some of the commands that may be affected.?
Any help much appreciated.
TIA.
crafty.
TIA.
crafty.
