Researching using a depletion mode MOSFET as a voltage indicator for 115V line by attaching an antenna to the gate and having it in close proximity to the outgoing side of a fuse. If the fuse blows, no voltage would be sensed, the MOSFET would turn on supplying battery voltage to a PicAxe chip whereby I could "do-stuff".
My thinking is the depletion mode MOSFET would keep batteries turned off conserving them until needed.
My concern is if a spike that blows a 0.5amp/250v fast blow fuse might damage the MOSFET even though it is physically disconnected from the fused circuit and is insulated from ground.
Any thoughts on things I need to consider?
