I am trying to create a command line based program to send serial data to a picaxe 28-X1
The general idea it that I can have a program and I can launch it with different values in the command line which are then sent out the serial port to the picaxe
i.e. launching "myprogram" with the number "123" in the command line will send "123" to the picaxe or having "abc" in the command line will send "abc" to the picaxe all the port and speed setting don't need changing so they can stay fixed inside the program and I can recompile if I need to change them which I don't mind one the string has been sent the program ends itself ready for the next time is it run I have already tried one method of doing this but it doesn't work properly feel free to ask for my vb code if you need it.
