microman171
Hello,
You guys must be getting good at fixing up problems, so here goes.
I have a VDRIVE 2 module, that worked for a friend. Now Ihave it, and I can't get it to write to a file or create one.
This is for yet another data logger project (seen a few of them by now, I know!)
I have copy pasted the code written by BJCKiwi (Couldn't find Technical's code...).
I get the correct D:/> prompt after file IO commands, but when plugging it into a computer I see nothing.
I tried to upgrade the firmware (to the latest version: 3.68) but I got no indication of it recognising the file. I can't remember the file name off the top of may head, but it was EXACTLY as written by technical. I even tried capitalising it as per the data sheet!
If you need to see the output from BJCKiwi's example, I can grab it =). I'm on a different computer at the moment...
Thanks for any help you can provide,
MM
EDIT: If it helps, I am using a 4GB Digitor Brand USB Stick formatted to FAT32. Will try FAT16...
MM
