I was wondering if anyone could spot in the below code any reason why my b0 variable keep resetting? Basically, I have a switch on the board that each time its pressed it increases the b0 vaiable by 1. This then operates the length of the pause time between each color change.
However, If I say set the pause at 4, with 4 presses of the button, it for some reason just resets itself back to 0
#picaxe 08m2
#no_data
setfreq m16
symbol Red = 0
symbol Green = 1
symbol Blue = 2
symbol speed = w0
symbol on_time = w2
symbol off_time = w3
setint %00001000, %00001000
readadc C.4,b3 ‘read the value
if b3<2 then chase ‘range 0-1
if b3>10 then lightsoff
lightsoff:
Low Green
Low Red
Low Blue
chase:
speed = b0 * 10000
RedOn:
for on_time = 0 to 5000 step 10
pulsout Red,on_time
off_time = 5000 - on_time
pauseus off_time
next on_time
high Red
pause speed
pause speed
pause speed
pause speed
pause speed
pause speed
BlueOff:
pulsout Blue,on_time
pauseus off_time
next on_time
low Blue
pause speed
pause speed
pause speed
pause speed
pause speed
pause speed
GreenOn:
pulsout Green,on_time
pauseus off_time
next on_time
high Green
pause speed
pause speed
pause speed
pause speed
pause speed
pause speed
RedOff:
pulsout Red ,on_time
pauseus off_time
next on_time
low Red
pause speed
pause speed
pause speed
pause speed
pause speed
pause speed
BlueOn:
for on_time = 0 to 5000 step 1000
pauseus off_time
next on_time
high Blue
pause speed
pause speed
pause speed
pause speed
pause speed
pause speed
GreenOff:
pulsout Green ,on_time
pauseus off_time
next on_time
low Green
pause speed
pause speed
pause speed
pause speed
pause speed
pause speed
interrupt:
if pinc.3 = 1 then
do while pinc.3 = 1 : loop ' wait for release
b0 = b0 + 1 // 7 ' 0 to 6
for b1 = 1 to b0
high Red
high Blue
high Green
pause 2000
low Red
low Blue
low Green
next b1
exit
