I've just got a quick question regarding making PCB's using the photoresist board, UV developing, then etch method.
I'm trying to set myself up to make them at home as cheap as possible.
All the UV boxes I've seen are pretty costly so I was wondering if just a UV light strip would do? Is UV particularly dangerous and at what power?
Could I just use one of these:
http://www.rapidonline.com/Electrical-Power/PA-Audio-Video/Lighting/Lamp-with-built-in-blacklight-UV-projector/79509/kw/UV
Just the replacement in this one connected to mains (or if the unit has a transformer low voltage DC would obviously be preferable)
http://cgi.ebay.co.uk/ULTRA-VIOLET-UV-FLUORESCENT-TUBE-LIGHT-BOX-450mm-15W_W0QQitemZ380123127182QQcmdZViewItemQQptZUK_ConElec_LightingLEDsStrobes_RL?hash=item380123127182&_trksid=p3286.c0.m14&_trkparms=72:1683|66:2|65:12|39:1|240:1318|301:1|293:1|294:50
I don't know much about UV light bulbs and tubes rolleyes. Would a simple UV bulb work (like the ones designed to replace real bulbs)? Do fluorescent tubes work with DC? If so what is the lowest voltages they can take?
