I have cobbled together a circuit similar to the Datalogger module AXE110 using the AXE091 development board. This all worked fine; I used the wizard to write a program; collected data using Datalink and all was well.
Then I changed from a serial connection to USB. The download works OK so I have set up the USB connection right I think. But I can't use the Datalink utility to transfer data. The wizard uses
serin 6, N4800, ("G")
and
serout 7,N4800 ...
to receive a prompt and send data. Why won't it work through the USB connection?
Thanks,
Derek
and
serout 7,N4800 ...
Thanks,
Derek
