When using Hserin with a 18m2 i am a little miffed to the values that are received and was wondering if someone can explain how the values relate to the data sent.
Example:- i send a "R" via serial and the value received with serrxd is 82 or R as expected, now using Hserin reading the same "R" it gives a value of 43 or ascii + why the 43???
Sending the same "R" through serial using a VB program gives a value of 171 using Hserin.
The results are always the same and i can make no sense of why, i do realize with Hserin it stores raw data but what format is this raw data.
