thursdaybloom
I have a USB->Serial cable at home already which I bought from Jaycar a while back. The part number on the packet is GUC-AD9 and the Jaycar part number is XC4834. I just wired up a 3-wire DB9 cable following the directions in the Manual Section 1.
I've set the cable up on COM5 before and it appears to be fine. When I try to download a program to my 08M it always fails. The Programming Editor brings up an error screen with a list of possible reasons why. None of them apply except maybe the 'unsupported USB->Serial adaptor'. How do I know if my cable that I have supports this 'breakout' command? When I run the 'test' via the Programming Editor and follow the instructions with testing voltage with my multimeter I always get -0.6V when the test LED is off [should get between 0V and -1V so this is fine]. When I click on the test LED the voltage moves to 4.1V, which I assume is a sufficient transition to high.
I was really hoping to get started on learning about Picaxes tonight but I just can't seem to be able to download the program
Can anyone help me at all? Much appreciated if you can
Cheers
Cheers
