Thanks
I wonder why PicAxe doesn't include the 5V on their programming cable ?
I notice Parallax also omits this (to me) obvious nice feature .
Consider the AXE027 cable.
It uses a standard 3.5mm stereo plug allowing the use of readily obtained stereo sockets for PCB or panel mounting.
By the nature of these plugs they have only 3 connections which allows for:
1. Tx
2. Rx
3. Ground
There is no spare connection available for +Vcc (as either +3.3V or +5V)
The earlier AXE026 programming lead was for connection from a PC serial DB9 connector.
The standard for the PC serial connectors for either 9 or 25 pin versions did not allow for the supply voltage to be made available on the connector, only ground and various signals.
The way some folks got around this for early PIC (not PICAXE) programmers and the like in the past, particularly with the 25 pin connectors, was to drive one or more of the unwanted signal pins to 0 giving a positive voltage due to signal inversion and using that as a source of power.
Had Rev Ed tried to bring out a +Vcc supply rail what connector would they choose as a standard?
It would need to be something that new comers to electronics can easily solder onto self assemble boards.
4 or 5 pin DIN? While readily available far more bulky.
USB connector? Compact but more fiddly to solder at home/school
