I've mentioned it in passing in another thread without resolve so here goes on its' own ....
I am running a cct that uses a PICAXE 18X to monitor light levels and every so often need to see what's going on so I leave the data cable plugged into the circuit continuously and plug the USB lead into my (battry powered) laptop as & when I need to......this usually but not always causes a re-start of the PIC.
Have attached the relevant part of the cct showing correct (?) reset and serial input connections
Any ideas why ?
Purely by chance I did it the other way around and plugged into the cct. board last and it didn't reset but that may have been a one off...or two off ..... in fact it usually seems to be OK doing it this way but I am not convinced.
I am not using the enhanced download circuit as I understand it is not required when using the USB lead - I don't have a serial port....so much for progress !
Any ideas why ?
