Hello!
I'm having a problem with the usb download cable. When trying to download/access the picaxe with the usb cable i just get the normal can't connect message. With the connection test button i get 0 and 2.1V with the diffrent lamp settings, i suppose 2.1V measured at serin pin at picaxe isn't enough?
Is there anything else that could be wrong, except the usb cable itself? I'm currently using the AXE090 Experimenter board for testing, with picaxe 18x installed. With the normal serial cable program download works without a hitch.
The problem is that the laptop i'd like to use for programming only has an usb port. As an alternative, would buying a usb-to-serial adapter work?
Thanks for any help you can offer
ps. For the first picaxe project I'm working on a wood fired boiler controller. It's going to control the inlet of air into the boiler, based on fumes temperature. So far I've got the stepper motor interface code working, the stepper will be used to control position of the inlet hatch.(i'm running bipolar stepper with L6219 IC). Next thing is to think some kind of measuring circuit for the PT-100 temperature sensor I have.
