I am building a switching circuit using a PICAXE28X1 which drives 5 74HC595 chained ICs. The idea is to send a pulse to one of the 40 outputs and switch off immediately after the pulse.
I intended to use the ULN2803A as an amplifier to each output point but in some older post on this forum I've read that this IC will not really switch off completely when the pulse goes low from the 28X1. In this old post it was suggested another IC, the UDN2981A but the reason is not very clear.
Is the 2803 reliable to switch off once the pulse from the picaxe goes low or is there any other IC which can do the job?
I need to shut off completely because of hazard it might cause in where it is going to be used. The idea is thus because the 595 itself is not in a known state when switched on and an astray bit might trigger the output even before the picaxe sends it's first output bit to any of the 5 chained IC's.
Any help greatly appreciated. Need to finish the circuit design by tomorrow.
