StigOfTheDump
Is there a tutorial on how to use this wizard?
I am converting a broken IP PTZ camera to a USB type. The camera itself will be wired with a USB extension cable. I am using SRF/ERF connected to the programming pins for testing the pan, tilt & zoom. Then I will make a remote control with an another ERF to control it. The casing is metal, apart from the smoked plastic dome, so I would like to mount the ERF in this dome.
I want to turn off the heartbeat LED. The wizard shows this as possible but I can't find how to use it and how to select whether I am configuring the SRF or ERF. Everything is working now and I don't want to mess up any other settings.
Thanks.
Stig
Thanks.
Stig
