Hei.
I wanted to ask if it would be wise to short the outputs that I am not using.
For an example. If I take a 08M and only use one output and one input. Instead of pulling the unused pins high or low can't I just short them, to destroy them, and then I don't need the pull up/down resistors.
I'm thinking this in the way to use as little power as posible for my application and also to make it as small as possible.
The main questions are: is there a high posibility to destroy some other function of the chip and also if I short the output is it the same as if the chip did not have the output in the first place (when looking at the fluctuation it can couse when not using pull up/down resistor).
Thanks
Simmi
Thanks
Simmi
