Andrei IRL
Hi. I have finally finished my Autonomous Car.
I have used the code from a similar project and just adopted it for mine.
Im just a bit unclear on two lines.
1st. - Why are we using
after
I understand that we are using low command before hand to stop servos/car to get more accurate reading of the distance but not sure why we are setting servo pins HIGH after distance is compared?
Thanks very much in advance.
high motorL,motorR
if distleft < blocked and distright < blocked then
'picaxe 08m
disablebod
setfreq m4
`Specifiyng Inputs and Outputs
symbol motorL=4 'servo output pins - pin 4
symbol motorR=2 'servo output pins - pin 2
symbol motorN=0 'servo output pins - pin 0
symbol sonic=1 'output pin for ultrasonic - pin 1
`Specifiyng Variables
symbol distance=w0 'result from ultrasonic
symbol distleft=w1 'distance when looking left
symbol distright=w2 'distance when looking righ
`Specifiyng Constants
symbol forwardL=185 `Right servo position signal for forward
symbol forwardR=75 `Left servo position signal for forward
symbol reverseL=75 `Right servo position signal for reverse
symbol reverseR=185 `Left servo position signal for reverse
symbol spinaround=1000 `Delay 1 sec to spin 180 degrees
symbol turn=100 `Delay to turn left or right
symbol blocked=40 'minimum safe distance 40cm
`Servo initiating
servo motorN,130
servopos motorN,200
servopos motorN,170
servo motorL,forwardL 'set pins as servo outputs - forwards
servo motorR,forwardR 'set pins as servo outputs - forwards
pause 500
Main:
gosub ping 'check to see if anything is infront of the robot
if distance>blocked then ' if nothing ahead
gosub ahead `then move forward
end if
gosub jump `if something is ahead go to jump Sub-routine
end
jump:
low motorL,motorR `stop the car
gosub look `go to look sub-routine
high motorL,motorR
gosub backwards
gosub spin180 'path blocked - can't turn
end if
if distleft>distright then
high motorL,motorR
gosub turnleft
end if
high motorL,motorR
gosub turnright
look:
servopos motorN,200 ' turn the head to the left
pause 500
gosub ping
let distleft=distance
servopos motorN,130 ' turn the head to the right
pause 600
gosub ping
let distright=distance
servopos motorN,170 ' return the head to centre
pause 500
ping:
ultra sonic, distance
pause 500
ahead:
backwards:
servopos motorL,reverseL
servopos motorR,reverseR
pause 2000
turnright:
servo motorR,reverseR
pause turn
turnleft:
servo motorL,reverseL
pause turn
spin180:
servo motorL,75
servo motorR,75
pause spinaround
