pleiser
first problem: the serial OLED I got from techsupplies (the limited time green version) makes a very high piched noise (the type you can barely hear that drives you crazy). Is this a common problem? what would a good solution be? where could I get a replacement now that techsupplies no longer has them?
problem 2: macaxepad seems to have a problem with #rem,#endrem, a few of them work but adding any more and it doesn't detect the endrem, it will stop being green after the endrem, but it will stay comented. eg:
will cause a syntax error: error: label not defined - aftercomment.
if I remove the rem and endrem it works as expected but I have to comment each line seperately (with ')
~Patrick
goto aftercomment
#rem
this rem will not stop
#endrem
aftercomment:
~Patrick
