Tecnoman...Maybe you could shield each IR receiver so that only signals from the intended "clicker" will be accepted (possibly fit the IR receivers with a small tube to make them more directional). I was able to do this on a project that was in the same room where a "clicker" that controlled my TV interfered with my project. JimSHi,
We would like to use several TVR010A within the same classroom. They will probably interfere with each other ; definitely not a solution.
So, we will have to build 6 remote controllers (Picaxe based), each one emitting the same address (TV) but different codes.
We need 5 commands for each controller. It is not clear if we can use every code in the range 0 to 98 (100?).
Other way : is it possible to configure the chip (SFR registers) to accept other addresses than TV?
No. The only way would be some type of bit-bashing to read and decode the incoming signal. There is a variety of example code on the forum which may help if you want to do that.is it possible to configure the chip (SFR registers) to accept other addresses than TV?
