Hey guys, having some problems with recieving a signal from the tsop receiver.
The idea is to sense a wall about 100mm away. Its going on a robot tafe project. At the moment the Ir LED is facing directly into the sensor for testing.
So far my diagnosis on the problem goes;
1. Check IR led with phone camera, its working,
2. Check maths for 36kHz output, working
3. Check wiring against pdf supplied by vishay, fine.
4. Put Vcc direct to output pin, pin senses the voltage.
5. Check that Vcc is about min for receiver, its fine at 4.5v (min is 2.7v)
6. Tested with and without CnR suppresion, wont work either way.
Here is the program, output pin of tsop goes to pin2.
pwmout 1 , 27, 56
b0 = pin2
sertxd("Pin2 = ",#b0,13,10)
Any help appreciated, please dont suggest other methods as IR is required for this project to get the pass mark.
Thanks guys!
pwmout 1 , 27, 56
b0 = pin2
Thanks guys!
