I have a project that requires that I control a DC motor through an H-bridge based on the setting of five switches. The code seems to work well until it hits the gosub watch_sgs, but then hangs. I don't understand what is different, i.e., why the prior gosub calls work and this one doesn't. Thanks for any insight.
ETA: The code isn't finished; I am just hung at this point.
'19 Feb 2016
'Schematic: RK Motor Controller 2.dch
'Code: RK Motor Controller 2.bas
'Overview: 'Controls motor for RK Door Closer
#picaxe 14M2 'Identify the PICAXE being used as a 14M2.
#no_data 'Prevent data from being downloaded to PICAXE.
symbol MAS = pinC.0
symbol PGS = pinC.1
symbol SGS = pinC.2
symbol FLS = pinC.3
symbol RLS = pinC.4
symbol Fwd = B.1
symbol Rvr = B.5
pullup %0001110000000000
'manual set sequence follows
if FLS = 1 and MAS = 0 then
high Fwd
low Rvr
'auto set sequence follows
elseif RLS = 1 and MAS = 1 then
low Fwd
high Rvr
'open sequence follows
elseif FLS = 0 and SGS = 1 and PGS = 0 and MAS = 1 then
gosub watch_PGS
pause 6000
high Fwd
low Rvr
gosub watch_FLS
low Fwd
low Rvr
gosub watch_SGS
low Fwd
high Rvr
low Rvr
low Fwd
watch_RLS:
if RLS = 1 then
exit
watch_FLS:
if FLS = 1 then
exit
watch_SGS:
if SGS = 0 then
exit
watch_PGS:
if PGS = 1 then
exit
watch_MAS:
if MAS = 1 then
exit
