I have finally received an inexpensive touchscreen from DX (http://www.dealextreme.com/details.dx/sku.20654) and I am ready to start experimenting. The theory seems simple enough and there is a good tutorial:
http://www.user.dccnet.com/wrigter/picaxe/08M sea of keys and touchpad encoder.htm that I plan to follow.
The very simple and elegant 08M code provided in that page uses the let dirs/pins commands to switch between measuring the two axes. What I would like to know is if it is possible/safe to use the discreet let pin/output/input/high/low commands for the same purpose. I'll be using the 20X2 and it would be much more convenient if I don't have to worry about the rest of the pins on the selected port. Hope you understand what I am getting at
Can two 'high'(or low) picaxe outputs be connected through a resistor? Is there any other dangerous connection?
