AndyGadget
I'm just about to have my first play with the 18M2 and it's touch sensors to get a feel for it in advance of a project I've got in mind.
Rather than using actual metal plates for the sensors, I was wondering if anyone has tried painting detector pads onto the back of a thin piece of plastic sheet with conductive paint. Connection could be done with small pins glued to the opposite side in an out-of-sight area and coated in the paint. Should be OK as long as the film isn't able to flex at that point.
Also, is it OK to use ribbon cable to connect to an array of sensors, or will the capacitance between cores cause interaction and false readings? If yes, would using alternate grounds in the ribbon cable stop this or would the capacitance to ground swamp the inputs?
Time to go and try it, methinks.
