Haxby,
Thanks for your July 2008 answers re stacked PSUs and windmill MPPT. Sorry for not thanking you before.
Q1.: Stacked PSUs: Pls elaborate, you mentioned if one uses stacked PSUs, then it needs a small modification to do it safely.
Q2.: "PSU takes DC inputs from 90 to 350 V, check label". The label would mention the AC input, not DC, how do i stop the magic smoke escaping? Am amazed at the range of DC inputs you quote.
Q3.: May I ask for your critique of the following MPPT approximation similar to yours:
step=?
pulsewidth = ?
oldwatts=0
read volts
read amps
calc watts
if watts >=oldwatts increase pulse width by step?
otherwise decrease pulse width by step?
oldwatts = watts
and let the Picaxe hunt to find a maximum wattage into battery from the windmill.
Q4.: What happens to the wattage produced when the Picaxe-driven (PWM) MOSFET has disconnected the batteries (load) from the PSUs, does it get lost? Do the small caps in the PSU store this wattage?
Q5.: The PSUs would be considered to be a load and would need to be disconnected from the mill until a certain RPM is reached otherwise the mill would never start. Is this correct?
So many questions, so little time!
An aside: As you are familiar with the Fisher & Paykel motor/generators, you may even be a Kiwi or Aussie, a fellow South-East Asian like myself?!?
Thanks,
step=?
pulsewidth = ?
oldwatts=0
read volts
read amps
calc watts
oldwatts = watts
Thanks,
