settimer 3036
Okay this sounds good but don't I have to set the timer first with the settimer command as showed in my first post?The 20X2 has a TIMER comand, which in association with a preload value can be used to count exact 1 second intervals.The 20x2 Toflag can be used to trigger an interupt each second.
#picaxe 20x2
setfreq m64
settimer 3036 'every major tick occurs every quarter second in timer
let b0 = timer / 4 'convert into seconds
if b0 = 10 then high b.6 endif 'after ten seconds light the LED
if b0 = 20 then low b.6 endif 'after twenty seconds turn off the LED
' Initialization
#picaxe 20x2 'define picaxe type
setfreq m64 'run internal oscillator @ 64MHz
hi2csetup i2cmaster,%11010000,i2cslow_64,i2cbyte 'paramters set,20x2 is master
pause 1000 ' pause a little
settimer 3036 'every major tick occurs every one second @ 64MHz
' Main
Main:
hi2cin 1,(minute,hour) 'obtain minute and hour information from DS1307
gosub Convert_Time_BCD_2_DEC 'convert hour and minute data to decimal
gosub Convert_Time_DEC_2_DISPLAY 'convert hour and minute data to display
gosub Half_Day_Indicator 'checks to see if AM/PM indicator should be on
gosub Display_Time 'display converted data
gosub Read_NES_Controller 'read NES controller's button status
gosub Check_Alarm 'check if alarm should be activated
Menu:
if nesregister = %11011111 then goto Set_Time 'hold "down" to set current time
if nesregister = %10111111 then goto Set_Alarm 'hold "left" to set alarm time
goto Main 'go to main
Here is the first half:Without you posting ALL of your code, we can't help you much with it.
#rem
File........... NES_Controller_Alarm_Clock_20M2.bas
Purpose........ Alarm Clock Functionality
Author......... Joseph Corleto
E-mail......... jc269@njit.edu
Started........ 05/14/2012
Finished....... --/--/----
Updated........ --/--/----
Notes
Seven Segment Display Convention:
Symbol bit7 bit6 bit5 bit4 bit3 bit2 bit1 bit0 binary eq decimal
0 0 0 1 1 1 1 1 1 00111111 63
1 0 0 0 0 0 1 1 0 00000110 6
2 0 1 0 1 1 0 1 1 01011011 91
3 0 1 0 0 1 1 1 1 01001111 79
4 0 1 1 0 0 1 1 0 01100110 102
5 0 1 1 0 1 1 0 1 01101101 109
6 0 1 1 1 1 1 0 1 01111101 125
7 0 0 1 0 0 1 1 1 00100111 39
8 0 1 1 1 1 1 1 1 01111111 127
9 0 1 1 0 0 1 1 1 01100111 103
H 0 1 1 1 0 1 1 0 01110110 118
i 0 0 0 1 0 0 0 0 01100111 16
n 0 1 0 1 0 1 0 0 01010100 84
E 0 1 1 1 1 0 0 1 01111001 121
F 0 1 1 1 0 0 0 1 01110001 113
r 0 1 0 1 0 0 0 0 01010000 80
o 0 1 0 1 1 1 0 0 01011100 92
A 0 1 1 1 0 1 1 1 01110111 119
. 1 0 0 0 0 0 0 0 10000000 128
| bit0 |
| bit5 | | bit1 |
| bit6 |
| bit4 | | bit2 |
| bit3 | | bit7 |
NES Controller Function's Description:
- The NES controller contains one 8-bit 4021 shift register inside.
- This register takes parallel inputs and converts them into a serial output.
- This code first latches the data and then shifts in the first bit on the data
line. Then it clocks and shifts in on the data line until all bits are
recieved.
- What is debugged are the button states of the NES controller.
- A logical "1" means the button is not pressed. A logical "0" means the button
is pressed.
- This code shifts the first bit of data into the LSB.
- The order of shifting for the buttons is shown in the table below:
Bit# | Button
0 | A
1 | B
2 | Select
3 | Start
4 | Up
5 | Down
6 | Left
7 | Right
- The NES controller pinout is shown below:
_________
| 1 O \ 1 - Ground
| | 2 - Clock
| 2 O O 7 | 3 - Latch
| | 4 - Data Out
| 3 O O 6 | 5 - No Connection
| | 6 - No Connection
| 4 O O 5 | 7 - +5V
|___________|
DS1307 RTC Specs and Configurations:
- Slave address: 1101000x
- Address size: 1 byte
- Bus speed: 100kHz
- Below is a table of the adresses and regsiters:
Address Register
00 Seconds ($0-$59)
01 Minutes ($0-$59)
02 Hours ($0-$23)
03 Day of week ($1-$7)
04 Date ($1-$31)
05 Month ($1-$12)
06 Year ($00-$99)
07 Control (set to $10)
08-$3F General Purpose RAM
- Below is table of 12 hour day and how the DS1307 RTC denotes it
12 hour 24 hour
12 am 0
1 am 1
2 am 2
3 am 3
4 am 4
5 am 5
6 am 6
7 am 7
8 am 8
9 am 9
10 am 10
11 am 11
12 pm 12
1 pm 13
2 pm 14
3 pm 15
4 pm 16
5 pm 17
6 pm 18
7 pm 19
8 pm 20
9 pm 21
10 pm 22
11 pm 23
"...Bit 6 of hours register is defined as the 12-hour or 24-hours mode-select
bit; 0 = AM; 1 = PM; In the 24-hour mode, bit 5 is the second 10-hour bit
(20-23 hours). The hours value must be re-entered whenever the 12/24-hour mode
bit is changed..."
Updates
#endrem
' EEPROM Data
' Constants
symbol mode = 1 'MSB first, idle low - shiftout for display
symbol ontime = 20 'on time for one display digit
symbol MINUS_6 = $10000 - 6 'represents "-6" for BCD to decimal conversion
symbol alarmmin = 0 'eeprom location to save minute of the alarm
symbol alarmhr = 1 'eeprom location to save hour of the alarm
symbol alarmstatus = 2 'eeprom location to save if alarm is on or off
symbol alarmtune = 3 'eeprom location to save alarm tune
symbol empty = 99 'represents an empty charactor for LED display
' Variables
symbol nesregister = b0 'holds what second it is
symbol minute = b1 'holds what minute it is
symbol hour = b2 'holds what hours it is
symbol hourtens = b3 'holds tens place of the hour
symbol hourones = b4 'holds ones place of the hour
symbol minutetens = b5 'holds tens place of the minute
symbol minuteones = b6 'holds ones place of the minute
symbol temp1 = b18 'temporary byte holder for calculations
symbol temp2 = b19 'temporary byte holder for calculations
' Pin Declarations
'Inputs:
symbol nesdata = pinc.6 'serial data to receive from 4021 (NES)
'Outputs:
symbol latch = c.0 'latch pin for 74HC595 (LED display)
symbol sdata = c.1 'serial data to feed into 74HC595 (LED display)
symbol sclk = c.2 'clock for 74HC595 (LED display)
symbol neslatch = c.5 'latch pin for 4021 (NES)
symbol nesclk = c.7 'clock for 4021 (NES)
symbol digit1 = b.0 'control pin for the hour's tens place
symbol digit2 = b.1 'control pin for the hour's ones place
symbol digit3 = b.2 'control pin for the minute's tens place
symbol digit4 = b.3 'control pin for the minute's ones place
symbol am_pm = b.4 'am/pm indicator led
symbol alarmpower = b.6 'power pin for 08M2 tune module
symbol tune1 = c.3 'tells 08M2 module to play tune 1 when high
symbol tune2 = c.4 'tells 08M2 module to play tune 2 when high
' Initialization
' Main
Main:
Menu:
Set_Time:
if nesregister = %11011101 then goto Set_Time_Hour '"down"+"B" increments hour
if nesregister = %11011110 then goto Set_Time_Minute '"down"+"A" increments min
if nesregister = %11111111 then goto Main 'no buttons pressed so main
Set_Time_Hour:
pause 500 '"debounce" time
if hour = 23 then 'hour is 23?
let hour = 0 'if so then reset to zero
else 'if not...
let hour = hour + 1 '...then increment it by one
endif 'done deciding
gosub Convert_Hour_DEC_2_BCD 'convert decimal hour to BCD
hi2cout 2,(hour) 'write to DS1307 new hour
goto Set_Time 'go back to setting time menu
Set_Time_Minute:
if minute = 59 then 'minute is 59?
let minute = 0 'if so then reset to zero
else 'if not...
let minute = minute + 1 '...then increment it by one
gosub Convert_Minute_DEC_2_BCD'convert decimal minute to BCD
hi2cout 1,(minute) 'write to DS1307 new hour
Set_Alarm:
read alarmhr,hour 'obtain last set alarm hour from memory
read alarmmin,minute 'obtain last set alarm minute from memory
gosub Play_Tune
if nesregister = %10111011 then goto Set_Alarm_Tune '"left"+"select" for tune
if nesregister = %10111101 then goto Set_Alarm_Hour '"left"+"B" increments hour
if nesregister = %10111110 then goto Set_Alarm_Minute'"left"+"A" increments min
if nesregister = %10110111 then goto Set_Alarm_Status'"left"+"start" toggles
'alarm status (on/off)
if nesregister = %11111111 then exit 'no buttons pressed so main
gosub Disable_Tune 'disable all tune pins and power pin to 08M2
Set_Alarm_Tune:
read alarmtune,temp1 'read previous set tune
if temp1 = 0 then let temp2 = 1 endif 'if prior was tune 1 make it tune 2
if temp1 = 1 then let temp2 = 0 endif 'if prior was tune 2 make it tune 1
write alarmtune,temp2 'save new alarm tune
goto Set_Alarm 'go back to setting alarm menu
Set_Alarm_Hour:
read alarmhr,hour 'read previous saved hour
else 'if not...
write alarmhr,hour 'save new alarm hour
Set_Alarm_Minute:
read alarmmin,minute 'read previous set minute
else 'if not...
write alarmmin,minute 'save new alarm minute
Set_Alarm_Status:
read alarmstatus,temp1 'read previous alarm status
let temp1 = 1 &/ temp1 'toggle status; if on then off, if off then on
'0 = alarm off; 1 = alarm on
write alarmstatus,temp1 'save new alarm status
if temp1 = 0 then goto Display_Off 'if new status is off then display this
if temp1 = 1 then goto Display_On 'if new status is on then display this
Display_Off:
'a for...next loop is used to create a delay while operating display
'basically, the alarm status, in this case off, shows this for a brief moment
for temp2 = 0 to 100 'execute loop 100 times
let hourtens = 119 'preload the letter "A" to be displayed in digit 1
let hourones = 92 'preload the letter "o" to be displayed in digit 2
let minutetens = 113 'preload the letter "F" to be displayed in digit 3
let minuteones = 113 'preload the letter "F" to be displayed in digit 4
next 'continue until temp2 = 100
goto Set_Alarm ;go back to setting alarm menu
Display_On:
'basically, the alarm status, in this case on, shows this for a brief moment
for temp1 = 0 to 100 'execute loop 100 times
let hourones = empty 'preload the letter " " to be displayed in digit 2
let minutetens = 92 'preload the letter "o" to be displayed in digit 3
let minuteones = 84 'preload the letter "n" to be displayed in digit 4
goto Set_Alarm 'go back to setting alarm data
' Sub-Routines
Read_NES_Controller:
'code below grabs data from the NES controller's hardware (4021)
pulsout neslatch,1 'latch the button states into the NES controller's 4021
let bit0 = nesdata 'grab "A" button state
pulsout nesclk,1 'clock for next button
let bit1 = nesdata 'grab "B" button state
let bit2 = nesdata 'grab "Select" button state
let bit3 = nesdata 'grab "Start" button state
let bit4 = nesdata 'grab "Up" button state
let bit5 = nesdata 'grab "Down" button state
let bit6 = nesdata 'grab "Left" button state
let bit7 = nesdata 'grab "Right" button state
return 'back where you came from
Convert_Time_BCD_2_DEC:
'code below takes time digits in BCD form and coverts them to decimal
let hour = hour / 16 * MINUS_6 + hour 'hippy's amazing BCD to DEC formula
let hourtens = hour dig 1 'grab tens place of the hour
let hourones = hour dig 0 'grab ones place of the hour
let minute = minute / 16 * MINUS_6 + minute 'hippy's amazing BCD to DEC formula
let minutetens = minute dig 1 'grab tens place of the minute
let minuteones = minute dig 0 'grab ones place of the minute
Convert_Time_DEC_2_DISPLAY:
'code below takes time digits in decimal form and converts them to display
lookup hourtens ,(63,6,91,79,102,109,125,39,127,103),hourtens
lookup hourones ,(63,6,91,79,102,109,125,39,127,103),hourones
lookup minutetens ,(63,6,91,79,102,109,125,39,127,103),minutetens
lookup minuteones ,(63,6,91,79,102,109,125,39,127,103),minuteones
let hourones = hourones + 128 'light up part of colon on display
let minutetens = minutetens + 128 'light up part of colon on display
Convert_Hour_DEC_2_BCD:
'code below takes the hour in decimal form and converts into BCD
let hourtens = hour / 10 'grab the tens place of the hour
let hourones = hour // 10 'grab the ones place of the hour
let hourtens = hourtens * 16 'shift tens place of hour to upper 4 bits
let hour = hourtens OR hourones 'OR hourtens w/ hourones; hour now BCD
Convert_Minute_DEC_2_BCD:
'code below takes the minute in decimal form and converts into BCD
let minutetens = minute / 10 'grab the tens place of the minute
let minuteones = minute // 10 'grab the ones place of the minute
let minutetens = minutetens * 16 'shift tens place of hour to upper 4 bits
let minute = minutetens OR minuteones'OR minutetens w/ minuteones;minute now BCD
Display_Time:
'code below takes display data from hourtens, hourones, minutetens, and
'minuteones and displays it to the LED display via a shift register
Hour_Tens:
if hourtens = 63 then goto Hour_Ones 'removes leading zero on display
if hourtens = empty then goto Hour_Ones 'if empty then skip this digit
shiftout sclk,sdata,mode,(hourtens) 'display tens place of the minute
pulsout latch,1 'latch data out to display
low digit1 'turn on tens place of the hour
pause ontime 'pause a little
input digit1 'turn off tens place of the hour
Hour_Ones:
if hourones = empty then goto Minute_Tens 'if empty then skip this digit
shiftout sclk,sdata,mode,(hourones) 'display ones place of the hour
low digit2 'turn on ones place of the hour
input digit2 'turn off ones place of the hour
Minute_Tens:
if minutetens = empty then goto Minute_Ones 'if empty then skip this digit
shiftout sclk,sdata,mode,(minutetens) 'display tens place of the minute
low digit3 'turn on tens place of the minute
input digit3 'turn off tens place of the minute
Minute_Ones:
if minuteones = empty then goto Done 'if empty then skip this digit
shiftout sclk,sdata,mode,(minuteones) 'display ones place of the minute
low digit4 'turn on ones place of the minute
input digit4 'turn off ones place of the minute
Done:
Half_Day_Indicator:
if hour >= 12 then high am_pm endif 'AM/PM led on when hour is >= to 12
if hour < 12 then low am_pm endif 'AM/PM led off when hour is < 12
Check_Alarm:
'code below compares saved alarm to current time and activates buzzer if need be
read alarmstatus,temp1 'check to see if alarm was set
'0 = not set; 1 = set
if temp1 = 0 then return endif 'if 0 then alarm was not set so exit routine
'but if temp1 = 1 then code below now checks to see if the alarm should sound
read alarmhr,temp1 'read hour of the alarm that was set
read alarmmin,temp2 'read minute of the alarm that was set
'when the saved hour/minute matches current hour/minute, a 1 indicates this
if temp1 = hour then let temp1 = 1 else let temp1 = 0 endif
if temp2 = minute then let temp2 = 1 else let temp2 = 0 endif
'when ANDing match indicators and result is 0 there is no match but is 1 if so
let temp1 = temp1 & temp2
if temp1 = 0 then gosub Disable_Tune 'if no match turn off alarm tune
if temp1 = 1 then gosub Play_Tune 'if a match turn on alarm tune
Play_Tune:
'code below signals the 08M2 sound module to play respective tune saved
high alarmpower 'turn on 08M2 sound module
if temp1 = 0 then high tune1 endif 'if a 0 then signal to play tune 1
if temp1 = 1 then high tune2 endif 'if a 1 then signal to play tune 2
Disable_Tune:
'code below signals the 08M2 sound module to disable all tunes
low alarmpower 'disable 08M2 sound module's power
low tune1 'disable alarm tune 1 signal
low tune2 ;disable alarm tune 2 signal
Yes I do this whenever I am debugging problem code I cannot find and it does result in a slap in the face most of he timesTo debug you problem, I suggest you insert 10 or 20 SerTxd ("a") statements at strategic locations in your program. Increment the "a" to "b", "c"... for each insertion. Run a test with the PE's terminal window open, logging the characters being sent by your PICAXE. Locate the last character to be logged (or repeated, if the program gets stuck in a loop). In the course of hunting down the problem, move your SerTxds or add more to further identify/isolate the problem code.
' Initialization
#terminal 76800
Symbol minute = b1
Symbol hour = b2
Symbol nesregister = b0
' Main
Main:
b27 = timer / 4 'convert into seconds
SerTxd(#hour, ":", #minute, ":", #b27," ")
Menu:
Set_Time:
Set_Alarm:
' Subroutines
Convert_Time_BCD_2_DEC: Return 'convert hour and minute data to decimal
Convert_Time_DEC_2_DISPLAY: Return 'convert hour and minute data to display
Half_Day_Indicator: Return 'checks to see if AM/PM indicator should be on
Display_Time: Return 'display converted data
Read_NES_Controller: Return 'read NES controller's button status
Check_Alarm: Return 'check if alarm should be activated
Wow thanks for taking the time to look at it so closely! Also, thanks for the compliment on the code structure, I thought it was messy and was going to clean it up later if possible And yes, you are right, I am a university student enrolled in a EE program and really the only experience in embedded design we have done is a lab with a Motorola 68000 microprocessor (a pain to program if you ask me). How could you tell I had an academic background?I printed your code out so that I could read on the ride home yesterday. Its well documented and fairly well structured too, which makes the job easier. It is written in a style similar to what I use, although I actively avoid the "goto" statement. I see that you possibly have an academic background.
Yes it is but I still can't see where the problem is coming from.I can't see any obvious problems but I notice there are no timer-related statements in it. Aren't they what you sespect is causing the problem?
You mean where I use the syntax "Timer" or "Timer3"?1. Can you show which Timer commands you are using and where they go in the code and why you are using them?
Not really, it seemed to work fine but I want to double and triple check this again. I'll let you know how this goes.2. Also you mentioned that you'd used SerTxd to try to isolate the problem. Any indication where the code gets lost?
