For BB, Hippy, Dippy, Westaus, BCJ, Eclectic, Andrew, JGlenn, Boriz and anybody else, happiness is:- "Manie now wants to buy a breadboard" ! The reason is simple. Something did not work on the PCB as intended ! For all newbies (like me) the following could have been prevented by buildng/testing on breadboard first.... Fortunately, I could easily salvage the PCB by shifting some resistors from 0V to +5V etc. but still....
Scenario:
Drive 2n7000 Mosfets from 40x1 outputs (gate to high), Mosfet then drives external (off board) power Mosfet or Transistor. Mosfet drain connected to +5V, sink to external driver.(See attached schematic)
Result:
Output from 2N7000 was insufficient ! Only 2.4V appeared on sink output. I wanted more.
Cure:
Change pulldown resistors (on Mosfet gate) to pull up resistors on PNP tranny. Replace Mosfets with PNP BC37's. Fortunately pnp's legs same configuration as Fets. (+5v remains +5V etc). Now I can drive external switch.
Shematics below show: "Old" incorrect circuit on left and "New" working circuit on right. If some noob learns something then my problem was worth it.
Hey guys, I could solve this one before asking ! Your education is working ! Keep it up ! And THANKS !
Manie
Scenario:
Result:
Cure:
Manie
