It's often the boring things now in electronics that blow budgets - cases/switches/rubber feet/screws etc. Hi tech is cheap but can look ugly if left bare! Here in NZ the every lowering price of basic smart phones is now almost matching the increasing price of their protective cases-this no doubt also holds in the rest of the world too.
With this trend in mind I've recently been pondering cost effective project "finish", especially based around diverse AA switched battery boxes. I'd explored this some months back with a 3 x AA box housing a 11 x 12 hole breadboard offcut. See =>http://www.instructables.com/id/Single-AA-LiFePo4-cell-powered-project-in-a-parti/.
Further brain storming & mockups show a partially gutted 4 x AA box as perhaps more appealing. If run from a single 3.2V LiFePO4 ("LFP") cell these larger boxes will neatly house a slightly trimmed (20 x12 hole) solderless breadboard or Kiwi Patch Boards in the liberated 3 cell spaces. For versatility a 2 x AA alkaline supply could be used, but the 4 x AA box would then only house an "outside in" centre rail circuit board in the 2 spare cell spaces. Programming points could be fitted on the board (as here), or run to a 3.5mm stereo socket mounted where the box supply wires normally emerge.
Naturally LFP cells will eventually need (smart) recharging, but a white,pink or blue LED makes a handy supply measure. These run brightly on 3-3.2V but dim & eventually fail to light by 2.5V. This near perfectly matches the "time to recharge" lower limit of a LFP cell.
Thoughts welcomed - Stan.
