Hi
After going around and around with the limitations of Picaxe word variable, I found this code on other forum:
After reads and understand the code, because the limitations of Picaxe and making my calculations, a can only get 16-65500 range of resolution, using 28x2 at 40 MHz with a 1us count increment on pulsin, but for rpm lower than 16 the pulsin gets a timeout.
I'm a newbie in picaxe and can't figure how to work around this. Someone with more knowledge can figure who?
' ****** * * * *MOTORCYCLE TACHOMETER by Warren Schroeder July 5, 2008
' ****** * * * ACCURATE OUTPUT FROM 0 TO 65500 RPM WITH 1RPM RESOLUTION
' ****** * * * * * * * * * * * * * MikroBASIC 7.2
' ****** * * * Tested On EasyPIC5 with PIC18F4431 @ 32MHz (8MHz x 4PLL)
' ****** *RPM Display on 16x2 LCD
' ****** *This TACHOMETER Code is developed for 60 input pulses per engine revolution
' ****** *Output Range is 0 to 62535 RPM in 1RPM Resolution with updates every second
' ****** *Timer0 is set up as a 16-bit counter with T0CK1 RC3 catching rising edges
' ****** *CCP1 is set up for 62500us interrupts using the special event feature
' ****** *which resets Timer1 on Compare-Match
' ****** *16 CCP1 Interrupts @ 62500us each = 1 Second
* Dim CCPR* *as Word Absolute $FBE* * *' CCPR1L:CCPR1H Pair as Word
* Dim Tally* as Byte
* Dim RPM* * as Word
* Dim TRPML* as Byte Absolute $30
* Dim TRPMH* as Byte Absolute $31
* Dim TRPM* *as Word Absolute $30
* Dim RPMStr as String[5]
* sub procedure interrupt()
* * * * *TRPML = TMR0L* * * * * * * *' capture Count; store in temp register
* * * * *TRPMH = TMR0H
* * * * *Tally = inc(Tally) And 15* *' Mod16 counter
* * * If Tally = 0 Then* * * * * * * ' if 1 second
* * * * *TMR0H = 0* * * * * * * * * *' clear Timer0 Counter
* * * * *TMR0L = 0
* * * * *RPM = TRPM* * * * * * * * * ' save RPM value for display
* * * End If
* * * PIR1.CCP1IF = 0* * * * * * * * ' clear interrupt flag
* end sub
* sub procedure Timer0_As_Counter()
* * * T0CON* *= 40* * * ' Off; 16Bit; Counter; rising edge; no prescaler
* * * TMR0H* *= 0* * * *' Clear Timer0 Count
* * * TMR0L* *= 0
* * * TRISC.3 = 1* * * *' RC3 is T0CK1 Counter Input
* end sub
* sub procedure CCP1_As_Timer()
* * * CCP1CON* = 11* * *' CCP1 Compare Match Special Event
* * * T1CON* * = 48* * *' Timer1 Off; Prescaler=8 = 1us ticks (125ns x 8)
* * * TMR1H* * = 0* * * ' Clear Timer1
* * * TMR1L* * = 0
* * * CCPR* * *= 62500* ' interrupt every 62500us
* * * PIE1.CCP1IE = 1* *' enable CCP1 interrupt
* * * PIR1.CCP1IF = 0* *' clear CCP1 interrupt flag
* * * INTCON* * * = 192 ' enable GIE and PEIE
* end sub
* * * ANSEL0 = 0* * * * ' disable adc's
* * * ANSEL1 = 0
* * * TRISA* = 0
* * * TRISB* = 0
* * * TRISC* = 0
* * * TRISD* = 0
* * * LATA* *= 0
* * * LATB* *= 0
* * * LATC* *= 0
* * * LATD* *= 0
* * * Timer0_As_Counter()
* * * CCP1_As_Timer()
* * * LCD_CONFIG(PORTB,3,2,1,0,PORTB,4,0,5)
* * * LCD_CMD(LCD_CURSOR_OFF)
* * * Tally = 0* * * * * ' reset timing tally
* * * T0CON.TMR0ON = 1* *' start Timer0 counter
* * * T1CON.TMR1ON = 1* *' start Timer1
* * * While 1=1
* * * * * delay_ms(50)
* * * * * WordToStr(RPM, RPMStr)
* * * * * LCD_OUT(1,1,RPMStr)
* * * * * LCD_OUT_CP(" RPM")
* * * Wend
end.
